Input & Output Devices
Audio Playback Devices
lcm-lora-sd
  1. Manually download the model and upload it to raspberrypi5, or pull the model repository with the following command.
Tip
If git lfs is not installed, please first refer to git lfs installation instructions for setup.
git clone https://huggingface.co/AXERA-TECH/lcm-lora-sdv1-5
File Description:
m5stack@raspberrypi:~/rsp/lcm-lora-sdv1-5 $ ls -lh
total 100K
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 17:10 asserts
-rw-rw-r-- 1 m5stack m5stack    0 Aug 11 17:09 config.json
-rw-rw-r-- 1 m5stack m5stack 1.2K Aug 11 17:09 Disclaimer.md
-rw-rw-r-- 1 m5stack m5stack 1.5K Aug 11 17:09 LICENSE
drwxrwxr-x 4 m5stack m5stack 4.0K Aug 11 17:14 models
-rw-rw-r-- 1 m5stack m5stack 5.7K Aug 11 17:09 README.md
-rw-rw-r-- 1 m5stack m5stack  117 Aug 11 17:09 requirements.txt
-rw-rw-r-- 1 m5stack m5stack  23K Aug 11 17:09 run_img2img_axe_infer.py
-rw-rw-r-- 1 m5stack m5stack  23K Aug 11 17:09 run_img2img_onnx_infer.py
-rw-rw-r-- 1 m5stack m5stack 7.8K Aug 11 17:09 run_txt2img_axe_infer_new.py
-rw-rw-r-- 1 m5stack m5stack 7.3K Aug 11 17:09 run_txt2img_axe_infer.py
-rw-rw-r-- 1 m5stack m5stack 7.4K Aug 11 17:09 run_txt2img_onnx_infer.py
python -m venv sd
source sd/bin/activate
  1. Install dependencies
sudo apt install cmake -y
  • Text-to-Image
python run_txt2img_axe_infer.py
Running result:
(sd) m5stack@raspberrypi:~/rsp/lcm-lora-sdv1-5$ python run_txt2img_axe_infer.py
prompt: Self-portrait oil painting, a beautiful cyborg with golden hair, 8k
text_tokenizer: ./models/tokenizer
text_encoder: ./models/text_encoder
unet_model: ./models/unet.axmodel
vae_decoder_model: ./models/vae_decoder.axmodel
time_input: ./models/time_input_txt2img.npy
save_dir: ./txt2img_output_axe.png
[INFO] SOC Name: AX650N
[INFO] Compiler version: 3.4 9215b7e5
text encoder take 4466.2ms
[INFO] Compiler version: 3.3 972f38ca
load models take 22582.9ms
unet once take 433.6ms
unet once take 433.5ms
unet once take 433.3ms
unet loop take 1736.7ms
vae inference take 914.2ms
save image take 254.3ms
  • Image-to-Image
Running result:
text encoder take 2962.1ms
load models take 14483.6ms
unet once take 433.2ms
unet once take 433.4ms
unet loop take 1736.4ms
vae inference take 914.0ms
save image take 233.2ms
