M5AtomS3R (Atom VoiceS3R and AtomS3R use the same main controller).
M5Unified and M5GFX libraries, and install all required dependencies as prompted.
Connect the device to the computer using a USB-C cable. Press and hold the side reset button for 3 seconds until the green LED flashes. The device will then enter download mode, and you can select the corresponding main controller and device port in Arduino IDE. The green LED turns off after the button is released, confirming that the device is in download mode.
#include "M5Unified.h"
M5.Speaker.tone(7000, 100); // frequency, duration
M5.Speaker.tone(4000, 20); // frequency, duration
}Copy the above program into Arduino IDE, click the upload button, and after compilation and uploading, the program will use the speaker to play beep sounds.
