产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
Jina CLIP v2
jina-clip-v2 是一个通用的多语言多模态文本与图像嵌入模型。
提示
git clone https://huggingface.co/AXERA-TECH/jina-clip-v2
文件说明
(ppocr) m5stack@raspberrypi:~/rsp/jina-clip-v2 $ ls -lh
total 1.7G
-rw-rw-r-- 1 m5stack m5stack  51K Oct 20 12:24 beach1.jpg
-rw-rw-r-- 1 m5stack m5stack    0 Oct 20 12:24 config.json
-rw-rw-r-- 1 m5stack m5stack 351M Oct 20 12:25 image_encoder.axmodel
drwxrwxr-x 2 m5stack m5stack 4.0K Oct 20 12:24 jina-clip-v2
-rw-rw-r-- 1 m5stack m5stack 1.3K Oct 20 12:24 README.md
-rw-rw-r-- 1 m5stack m5stack 3.2K Oct 20 12:24 run_axmodel.py
-rw-rw-r-- 1 m5stack m5stack 1.3G Oct 20 12:26 text_encoder.axmodel
2. 创建虚拟环境
```bash
python -m venv clip
  1. 激活虚拟环境
source clip/bin/activate
  1. 安装依赖包
pip install torch pillow transformers timm torchvision
  1. 运行
python run_axmodel.py
运行结果:
(clip) m5stack@raspberrypi:~/rsp/jina-clip-v2 $ python3 run_axmodel.py -i beach1.jpg -t "beautiful sunset over the beach" -iax ./image_encoder.axmodel -tax ./text_encoder.axmodel --hf_path ./jina-clip-v2
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 df480136
[INFO] Compiler version: 4.2 27910799
Using a slow image processor as `use_fast` is unset and a slow processor was saved with this model. `use_fast=True` will be the default behavior in v4.52, even if the model was saved with a slow processor. This will result in minor differences in outputs. You'll still be able to use a slow processor with `use_fast=False`.
A new version of the following files was downloaded from https://huggingface.co/jinaai/jina-clip-implementation:
- transform.py
. Make sure to double-check they do not contain any added malicious code. To avoid downloading new versions of the code file, you can pin a revision.
text -> image: 0.3140323
