产品上手指引
大语言模型
IoT 测量仪表
Ethernet 摄像头
拨码开关&引脚切换
Module GPS v2.0
Module ExtPort For Core2
Module LoRa868 V1.2
Qwen2.5-0.5B
提示
git clone https://huggingface.co/AXERA-TECH/Qwen2.5-0.5B-Instruct-GPTQ-Int4
文件说明
m5stack@raspberrypi:~/rsp/Qwen2.5-0.5B-Instruct-GPTQ-Int4 $ ls -lh
total 2.9M
-rw-rw-r-- 1 m5stack m5stack    0 Aug 12 10:30 config.json
-rw-rw-r-- 1 m5stack m5stack 976K Aug 12 10:30 main_axcl_aarch64
-rw-rw-r-- 1 m5stack m5stack 999K Aug 12 10:30 main_axcl_x86
-rw-rw-r-- 1 m5stack m5stack 932K Aug 12 10:30 main_prefill
-rw-rw-r-- 1 m5stack m5stack  277 Aug 12 10:30 post_config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 10:30 qwen2.5-0.5b-gptq-int4-ax650
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 10:30 qwen2.5_tokenizer
-rw-rw-r-- 1 m5stack m5stack 4.2K Aug 12 10:30 qwen2.5_tokenizer.py
-rw-rw-r-- 1 m5stack m5stack 7.3K Aug 12 10:30 README.md
-rw-rw-r-- 1 m5stack m5stack  520 Aug 12 10:30 run_qwen2.5_0.5b_gptq_int4_ax650.sh
-rw-rw-r-- 1 m5stack m5stack  525 Aug 12 10:30 run_qwen2.5_0.5b_gptq_int4_axcl_aarch64.sh
-rw-rw-r-- 1 m5stack m5stack  521 Aug 12 10:30 run_qwen2.5_0.5b_gptq_int4_axcl_x86.sh
提示
如果之前已经创建了 qwen 的虚拟环境,不需要重新创建,只需要激活即可
  1. 创建虚拟环境
python -m venv qwen
  1. 激活虚拟环境
source qwen/bin/activate
  1. 安装依赖包
  1. 启动 tokenizer 解析器
python qwen2.5_tokenizer.py --port 12345
  1. 运行 tokenizer 服务,Host ip 默认为 localhost,端口号设置为 12345,运行后信息如下:
(qwen) m5stack@raspberrypi:~/rsp/Qwen2.5-0.5B-Instruct-GPTQ-Int4 $ python qwen2.5_tokenizer.py --port 12345
None None 151645 <|im_end|>
<|im_start|>system
You are Qwen, created by Alibaba Cloud. You are a helpful assistant.<|im_end|>
<|im_start|>user
hello world<|im_end|>
<|im_start|>assistant
[151644, 8948, 198, 2610, 525, 1207, 16948, 11, 3465, 553, 54364, 14817, 13, 1446, 525, 264, 10950, 17847, 13, 151645, 198, 151644, 872, 198, 14990, 1879, 151645, 198, 151644, 77091, 198]
http://localhost:12345
提示
以下操作需要新建一个 raspberrypi 的终端。
  1. 设置可执行权限
chmod +x main_axcl_aarch64 run_qwen2.5_0.5b_gptq_int4_axcl_aarch64.sh
  1. 启动 Qwen2.5 模型推理服务
./run_qwen2.5_0.5b_gptq_int4_axcl_aarch64.sh
成功启动后信息如下:
m5stack@raspberrypi:~/rsp/Qwen2.5-0.5B-Instruct-GPTQ-Int4$ ./run_qwen2.5_0.5b_gptq_int4_axcl_aarch64.sh
bos_id: -1, eos_id: 151645
  3% | ██                                |   1 /  27 [0.00s<0.05s, 500.00 count/s] tokenizer init
  96% | ███████████████████████████████   |  26 /  27 [8.35s<8.67s, 3.11 count/s] init 23 axmodel ok
  100% | ████████████████████████████████ |  27 /  27 [11.63s<11.63s, 2.32 count/s] init post axmodel ok
[I][                            Init][ 226]: max_token_len : 1024
[I][                            Init][ 231]: kv_cache_size : 128, kv_cache_num: 1024
    "enable_temperature": true,
    "penalty_window": 20,
    "repetition_penalty": 1.2,
    "temperature": 0.9,
    "top_k": 10,
    "top_p": 0.8
>> hello
Hello! How can I help you today? Let me know if you would like me to assist with anything else.
[N][                             Run][ 610]: hit eos,avg 27.05 token/s
