git clone https://huggingface.co/AXERA-TECH/Qwen2.5-VL-3B-Instruct文件说明
m5stack@raspberrypi:~/rsp/Qwen2.5-VL-3B-Instruct $ ls -lh
total 10M
-rw-rw-r-- 1 m5stack m5stack    0 Aug 12 16:37 config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 16:52 image
-rw-rw-r-- 1 m5stack m5stack 6.3M Aug 12 16:52 main
-rwxrwxr-x 1 m5stack m5stack  132 Aug 12 16:37 main_ax650
-rwxrwxr-x 1 m5stack m5stack 1.8M Aug 12 16:52 main_axcl_aarch64
-rwxrwxr-x 1 m5stack m5stack 1.8M Aug 12 16:52 main_axcl_x86
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 16:37 python
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 16:52 qwen2_5-vl-3b-image-ax650
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 16:47 Qwen2.5-VL-3B-Instruct-AX650-chunk_prefill_512
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 16:55 qwen2_5-vl-3b-video-ax650
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 16:37 qwen2_5-vl-tokenizer
-rw-rw-r-- 1 m5stack m5stack 9.0K Aug 12 16:37 qwen2_tokenizer_images.py
-rw-rw-r-- 1 m5stack m5stack  16K Aug 12 16:37 qwen2_tokenizer_video_308.py
-rw-rw-r-- 1 m5stack m5stack  14K Aug 12 16:37 README.md
-rwxrwxr-x 1 m5stack m5stack  708 Aug 12 16:37 run_qwen2_5_vl_image_axcl_aarch64.sh
-rwxrwxr-x 1 m5stack m5stack  704 Aug 12 16:37 run_qwen2_5_vl_image_axcl_x86.sh
-rwxrwxr-x 1 m5stack m5stack  780 Aug 12 16:37 run_qwen2_5_vl_image.sh
-rwxrwxr-x 1 m5stack m5stack  705 Aug 12 16:37 run_qwen2_5_vl_video_axcl_aarch64.sh
-rwxrwxr-x 1 m5stack m5stack  701 Aug 12 16:37 run_qwen2_5_vl_video_axcl_x86.sh
-rwxrwxr-x 1 m5stack m5stack  777 Aug 12 16:37 run_qwen2_5_vl_video.sh
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 16:37 videopython -m venv qwensource qwen/bin/activatepip install transformers jinja2python qwen2_tokenizer_images.py --port 12345(qwen) m5stack@raspberrypi:~/rsp/Qwen2.5-VL-3B-Instruct $ python qwen2_tokenizer_images.py --port 12345
None None 151645 <|im_end|>
[151644, 8948, 198, 2610, 525, 264, 10950, 17847, 13, 151645, 198, 151644, 872, 198, 151652, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151655, 151653, 74785, 419, 2168, 13, 151645, 198, 151644, 77091, 198]
281
21
http://localhost:12345chmod +x main_axcl_aarch64 run_qwen2_5_vl_image_axcl_aarch64.sh./run_qwen2_5_vl_image_axcl_aarch64.sh成功启动后信息如下:
m5stack@raspberrypi:~/rsp/Qwen2.5-VL-3B-Instruct $ ./run_qwen2_5_vl_image_axcl_aarch64.sh
[I][                            Init][ 162]: LLM init start
bos_id: -1, eos_id: 151645
img_start_token: 151652
img_context_token: 151655
  2% | █                                 |   1 /  39 [0.01s<0.20s, 200.00 count/s] tokenizer init ok
  [I][Init][  45]: LLaMaEmbedSelector use mmap
100% | ████████████████████████████████ |  39 /  39 [72.58s<78.62s, 0.50 count/s] init post axmodel ok,remain_cmm(-1 MB)
input size: 1
        1 x 1024 x 392 x 3 size:1204224
output size: 1
        256 x 2048 size:2097152
[I][                            Init][ 267]: IMAGE_CONTEXT_TOKEN: 151655, IMAGE_START_TOKEN: 151652
[I][                            Init][ 328]: image encoder output float32
[I][                            Init][ 340]: max_token_len : 1023
[I][                            Init][ 343]: kv_cache_size : 256, kv_cache_num: 1023
[I][                            Init][ 351]: prefill_token_num : 128
[I][                            Init][ 355]: grp: 1, prefill_max_token_num : 1
[I][                            Init][ 355]: grp: 2, prefill_max_token_num : 128
[I][                            Init][ 355]: grp: 3, prefill_max_token_num : 256
[I][                            Init][ 355]: grp: 4, prefill_max_token_num : 384
[I][                            Init][ 355]: grp: 5, prefill_max_token_num : 512
[I][                            Init][ 359]: prefill_max_token_num : 512
________________________
|    ID| remain cmm(MB)|
|     0|             -1|
[E][                     load_config][ 278]: config file(post_config.json) open failed
[W][                            Init][ 452]: load postprocess config(post_config.json) failed
[I][                            Init][ 456]: LLM init ok
prompt >> who are you?
image >>
[I][                             Run][ 625]: input token num : 23, prefill_split_num : 1
[I][                             Run][ 659]: input_num_token:23
[I][                             Run][ 796]: ttft: 558.68 ms
I am a large language model created by Alibaba Cloud. I am called Qwen.
[N][                             Run][ 949]: hit eos,avg 4.81 token/s
prompt >>
 prompt >> describe this picture
image >> image/ssd_car.jpg
[I][                          Encode][ 539]: image encode time : 773.948975 ms, size : 524288
[I][                             Run][ 625]: input token num : 280, prefill_split_num : 3
[I][                             Run][ 659]: input_num_token:128
[I][                             Run][ 659]: input_num_token:24
[I][                             Run][ 796]: ttft: 2076.95 ms
The picture shows a busy urban street scene in what appears to be a city center. A red double-decker bus is prominently featured in the foreground, with a large advertisement on its side that reads, "THINGS GET MORE EXITING WHEN YOU SAY 'YES' VirginMoney.co.uk." The bus is driving on the right side of the road, which is typical in the UK.
In the background, there are several pedestrians walking on the sidewalk, and a few cars are visible on the road. The buildings lining the street are modern and have large windows, suggesting a commercial or business district. The street is well-maintained, with clear pedestrian crossings and a clear separation between the road and the sidewalk.
The overall atmosphere of the image is bustling and typical of a busy city environment.
[N][                             Run][ 949]: hit eos,avg 4.83 token/spython qwen2_tokenizer_video_308.py --port 12345(qwen) m5stack@raspberrypi:~/rsp/Qwen2.5-VL-3B-Instruct $ python qwen2_tokenizer_video_308.py --port 12345
[151644, 8948, 198, 2610, 525, 264, 10950, 17847, 13, 151645, 198, 151644, 872, 198, 151652, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151656, 151653, 53481, 100158, 99487, 87140, 104597, 151645, 198, 151644, 77091, 198]
510
21
http://localhost:12345chmod +x main_axcl_aarch64 run_qwen2_5_vl_video_axcl_aarch64.sh./run_qwen2_5_vl_video_axcl_aarch64.sh成功启动后信息如下:
m5stack@raspberrypi:~/rsp/Qwen2.5-VL-3B-Instruct $ ./run_qwen2_5_vl_video_axcl_aarch64.sh
img_context_token: 151656
  2% | █                                 |   1 /  39 [0.00s<0.12s, 333.33 count/s] tokenizer init ok
100% | ████████████████████████████████ |  39 /  39 [75.71s<77.70s, 0.50 count/s] init post axmodel ok,remain_cmm(3220 MB)
input size: 1
        1 x 484 x 392 x 3 size:569184
output size: 1
        121 x 2048 size:991232
[I][                            Init][ 267]: IMAGE_CONTEXT_TOKEN: 151656, IMAGE_START_TOKEN: 151652
|    ID| remain cmm(MB)|
|     0|             -1|
prompt >> Describe the content of this video
image >> video
video/frame_0000.jpg
video/frame_0008.jpg
video/frame_0016.jpg
video/frame_0024.jpg
video/frame_0032.jpg
video/frame_0040.jpg
video/frame_0048.jpg
video/frame_0056.jpg
[I][                          Encode][ 539]: image encode time : 1480.802002 ms, size : 991232
[I][                             Run][ 625]: input token num : 511, prefill_split_num : 4
[I][                             Run][ 659]: input_num_token:127
[I][                             Run][ 796]: ttft: 3032.74 ms
The video depicts two ground squirrels engaging in a playful interaction on a rocky path. The squirrels are facing each other, and their front paws are raised, as if they are playfully bumping or scratching each other. The background features a scenic mountain landscape with green hills and a clear blue sky, suggesting a sunny day. The squirrels' fur is a mix of brown, black, and white, and their tails are bushy and fluffy. The overall atmosphere of the video is light-hearted and playful, capturing a moment of natural behavior in a beautiful outdoor setting.
[N][                             Run][ 949]: hit eos,avg 4.86 token/s
prompt >>| 模型 | 量化方式 | image encode (ms) | tftt (ms) | token/s |
| Qwen2.5-3B-VL | w8a16 | 773.95 | 558.68 | 4.81 |
