Input & Output Devices
Audio Playback Devices
sherpa-onnx
sherpa-onnx is a lightweight speech recognition and processing toolbox based on ONNX Runtime, focusing on achieving high-performance, low-latency streaming and offline recognition on local devices. It now supports LLM8850 as the inference backend and NPU acceleration. Official Documentation
  1. Manual model download and upload it to raspberrypi5, or pull the model repository using the following command.
Tip
If git lfs is not installed yet, please refer to git lfs installation guide for installation.
git clone https://huggingface.co/M5Stack/SenseVoiceSmall-axmodel
File description:
m5stack@raspberrypi:~/rsp/SenseVoiceSmall-axmodel $ ls -lh
total 328K
drwxrwxr-x 2 m5stack m5stack 4.0K Dec  9 11:55 ax630c
drwxrwxr-x 2 m5stack m5stack 4.0K Dec  9 11:55 ax650
-rw-rw-r-- 1 m5stack m5stack   24 Dec  9 11:54 README.md
drwxrwxr-x 2 m5stack m5stack 4.0K Dec  9 11:54 test_wavs
-rw-rw-r-- 1 m5stack m5stack 309K Dec  9 11:54 tokens.txt
  1. Get the pre-compiled program Manual download link
wget https://github.com/k2-fsa/sherpa-onnx/releases/download/v1.12.19/sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared.tar.bz2
tar xvf sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared.tar.bz2
rm sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared.tar.bz2
File description:
m5stack@raspberrypi:~/rsp/SenseVoiceSmall-axmodel $ ls -lh sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/
total 47M
-rwxr-xr-x 1 m5stack m5stack 1.9M Dec  8 12:04 sherpa-onnx
-rwxr-xr-x 1 m5stack m5stack 1.9M Dec  8 12:04 sherpa-onnx-alsa
-rwxr-xr-x 1 m5stack m5stack 1.9M Dec  8 12:04 sherpa-onnx-alsa-offline
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-alsa-offline-audio-tagging
-rwxr-xr-x 1 m5stack m5stack 453K Dec  8 12:04 sherpa-onnx-alsa-offline-speaker-identification
-rwxr-xr-x 1 m5stack m5stack 710K Dec  8 12:04 sherpa-onnx-keyword-spotter
-rwxr-xr-x 1 m5stack m5stack 710K Dec  8 12:04 sherpa-onnx-keyword-spotter-alsa
-rwxr-xr-x 1 m5stack m5stack 903K Dec  8 12:04 sherpa-onnx-keyword-spotter-microphone
-rwxr-xr-x 1 m5stack m5stack 2.1M Dec  8 12:04 sherpa-onnx-microphone
-rwxr-xr-x 1 m5stack m5stack 2.1M Dec  8 12:04 sherpa-onnx-microphone-offline
-rwxr-xr-x 1 m5stack m5stack 582K Dec  8 12:04 sherpa-onnx-microphone-offline-audio-tagging
-rwxr-xr-x 1 m5stack m5stack 582K Dec  8 12:04 sherpa-onnx-microphone-offline-speaker-identification
-rwxr-xr-x 1 m5stack m5stack 1.9M Dec  8 12:04 sherpa-onnx-offline
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-offline-audio-tagging
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-offline-denoiser
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-offline-language-identification
-rwxr-xr-x 1 m5stack m5stack 1.9M Dec  8 12:04 sherpa-onnx-offline-parallel
-rwxr-xr-x 1 m5stack m5stack 325K Dec  8 12:04 sherpa-onnx-offline-punctuation
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-offline-source-separation
-rwxr-xr-x 1 m5stack m5stack 517K Dec  8 12:04 sherpa-onnx-offline-speaker-diarization
-rwxr-xr-x 1 m5stack m5stack 2.4M Dec  8 12:04 sherpa-onnx-offline-tts
-rwxr-xr-x 1 m5stack m5stack 2.6M Dec  8 12:04 sherpa-onnx-offline-tts-play
-rwxr-xr-x 1 m5stack m5stack 2.4M Dec  8 12:04 sherpa-onnx-offline-tts-play-alsa
-rwxr-xr-x 1 m5stack m5stack 2.2M Dec  8 12:04 sherpa-onnx-offline-websocket-server
-rwxr-xr-x 1 m5stack m5stack 2.4M Dec  8 12:04 sherpa-onnx-offline-zeroshot-tts
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-online-punctuation
-rwxr-xr-x 1 m5stack m5stack 645K Dec  8 12:04 sherpa-onnx-online-websocket-client
-rwxr-xr-x 1 m5stack m5stack 2.2M Dec  8 12:04 sherpa-onnx-online-websocket-server
-rwxr-xr-x 1 m5stack m5stack 261K Dec  8 12:04 sherpa-onnx-pa-devs
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-vad
-rwxr-xr-x 1 m5stack m5stack 389K Dec  8 12:04 sherpa-onnx-vad-alsa
-rwxr-xr-x 1 m5stack m5stack 1.9M Dec  8 12:04 sherpa-onnx-vad-alsa-offline-asr
-rwxr-xr-x 1 m5stack m5stack 582K Dec  8 12:04 sherpa-onnx-vad-microphone
-rwxr-xr-x 1 m5stack m5stack 2.1M Dec  8 12:04 sherpa-onnx-vad-microphone-offline-asr
-rwxr-xr-x 1 m5stack m5stack 2.1M Dec  8 12:04 sherpa-onnx-vad-microphone-simulated-streaming-asr
-rwxr-xr-x 1 m5stack m5stack 2.0M Dec  8 12:04 sherpa-onnx-vad-with-offline-asr
-rwxr-xr-x 1 m5stack m5stack 2.0M Dec  8 12:04 sherpa-onnx-vad-with-online-asr
-rwxr-xr-x 1 m5stack m5stack 195K Dec  8 12:04 sherpa-onnx-version
  1. Speech file recognition.
./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-offline --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl test_wavs/en.wav
Recognition result:
m5stack@raspberrypi:~/rsp/SenseVoiceSmall-axmodel $ ./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-offline --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl test_wavs/en.wav
/k2-fsa/sherpa-onnx/sherpa-onnx/csrc/parse-options.cc:Read:373 ./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-offline --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl test_wavs/en.wav
OfflineRecognizerConfig(feat_config=FeatureExtractorConfig(sampling_rate=16000, feature_dim=80, low_freq=20, high_freq=-400, dither=0, normalize_samples=True, snip_edges=False), model_config=OfflineModelConfig(transducer=OfflineTransducerModelConfig(encoder_filename="", decoder_filename="", joiner_filename=""), paraformer=OfflineParaformerModelConfig(model=""), nemo_ctc=OfflineNemoEncDecCtcModelConfig(model=""), whisper=OfflineWhisperModelConfig(encoder="", decoder="", language="", task="transcribe", tail_paddings=-1), fire_red_asr=OfflineFireRedAsrModelConfig(encoder="", decoder=""), tdnn=OfflineTdnnModelConfig(model=""), zipformer_ctc=OfflineZipformerCtcModelConfig(model=""), wenet_ctc=OfflineWenetCtcModelConfig(model=""), sense_voice=OfflineSenseVoiceModelConfig(model="ax650/model-10-seconds.axmodel", language="auto", use_itn=False), moonshine=OfflineMoonshineModelConfig(preprocessor="", encoder="", uncached_decoder="", cached_decoder=""), dolphin=OfflineDolphinModelConfig(model=""), canary=OfflineCanaryModelConfig(encoder="", decoder="", src_lang="", tgt_lang="", use_pnc=True), omnilingual=OfflineOmnilingualAsrCtcModelConfig(model=""), telespeech_ctc="", tokens="tokens.txt", num_threads=2, debug=False, provider="axcl", model_type="", modeling_unit="cjkchar", bpe_vocab=""), lm_config=OfflineLMConfig(model="", scale=0.5, lodr_scale=0.01, lodr_fst="", lodr_backoff_id=-1), ctc_fst_decoder_config=OfflineCtcFstDecoderConfig(graph="", max_active=3000), decoding_method="greedy_search", max_active_paths=4, hotwords_file="", hotwords_score=1.5, blank_penalty=0, rule_fsts="", rule_fars="", hr=HomophoneReplacerConfig(lexicon="", rule_fsts=""))
Creating recognizer ...
recognizer created in 4.263 s
Started
Done!
test_wavs/en.wav
{"lang": "<|en|>", "emotion": "<|EMO_UNKNOWN|>", "event": "<|Speech|>", "text": "the tribal chieftain called for the boy and presented him with fifty pieces of gold", "timestamps": [0.90, 1.26, 1.56, 1.80, 2.16, 2.46, 2.76, 2.94, 3.12, 3.60, 3.96, 4.50, 4.74, 5.10, 5.52, 5.88, 6.24], "durations": [], "tokens":["the", " tri", "bal", " chief", "tain", " called", " for", " the", " boy", " and", " presented", " him", " with", " fifty", " pieces", " of", " gold"], "ys_log_probs": [], "words": []}
num threads: 2
decoding method: greedy_search
Elapsed seconds: 0.105 s
Real time factor (RTF): 0.105 / 7.152 = 0.015
  1. Speech file recognition with VAD segmentation.
Get the VAD model
wget https://github.com/k2-fsa/sherpa-onnx/releases/download/asr-models/silero_vad.onnx
Get a long speech file or prepare your own
wget https://github.com/k2-fsa/sherpa-onnx/releases/download/asr-models/Obama.wav
Start recognition
./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-vad-with-offline-asr --silero-vad-model=silero_vad.onnx --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl Obama.wav
Recognition result:
m5stack@raspberrypi:~/rsp/SenseVoiceSmall-axmodel $ ./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-vad-with-offline-asr --silero-vad-model=silero_vad.onnx --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl Obama.wav
/k2-fsa/sherpa-onnx/sherpa-onnx/csrc/parse-options.cc:Read:373 ./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-vad-with-offline-asr --silero-vad-model=silero_vad.onnx --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl Obama.wav
VadModelConfig(silero_vad=SileroVadModelConfig(model="silero_vad.onnx", threshold=0.5, min_silence_duration=0.5, min_speech_duration=0.25, max_speech_duration=20, window_size=512, neg_threshold=-1), ten_vad=TenVadModelConfig(model="", threshold=0.5, min_silence_duration=0.5, min_speech_duration=0.25, max_speech_duration=20, window_size=256), sample_rate=16000, num_threads=1, provider="cpu", debug=False)
Recognizer created!
Started
Reading: Obama.wav
Started!
9.286 -- 12.428: everybody all right everybody go ahead and have a seat
13.094 -- 14.988: how's everybody doing today
18.694 -- 20.748: how about tim spicer
25.894 -- 31.948: i am here with students at wakefield high school in arlington virginia
297.318 -- 314.284: you want to be a doctor or a teacher or a police officer you want to be a nurse or an architect a lawyer or a member of our military you're going to need a good education
315.174 -- 319.852: you've got to train for it and work for it and learn for it
320.518 -- 323.660: and this isn't just important for your own life and your own future
324.678 -- 333.004: what you make of your education will decide nothing less than the future of this country the future of america depends on you
num threads: 2
Elapsed seconds: 6.061 s
Real time factor (RTF): 6.061 / 334.234 = 0.018
  1. Real-time non-streaming recognition via microphone. Get microphone device list
aplay -l
m5stack@raspberrypi:~/rsp/SenseVoiceSmall-axmodel $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: vc4hdmi0 [vc4-hdmi-0], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: vc4hdmi1 [vc4-hdmi-1], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Subdevices: 1/1
card 2: Audio [AB13X USB Audio], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
Start real-time non-streaming recognition
./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-vad-alsa-offline-asr --silero-vad-model=silero_vad.onnx --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl plughw:2,0 # Note: replace with the actual microphone device name
Recognition result:
m5stack@raspberrypi:~/rsp/SenseVoiceSmall-axmodel $ ./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-vad-alsa-offline-asr --silero-vad-model=silero_vad.onnx --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl plughw:2,0
/k2-fsa/sherpa-onnx/sherpa-onnx/csrc/parse-options.cc:Read:373 ./sherpa-onnx-v1.12.19-axcl-linux-aarch64-shared/bin/sherpa-onnx-vad-alsa-offline-asr --silero-vad-model=silero_vad.onnx --sense-voice-model=ax650/model-10-seconds.axmodel --tokens=tokens.txt --provider=axcl plughw:2,0
Recognizer created!
Current sample rate: 16000
Recording started!
Use recording device: plughw:2,0
Started. Please speak
 0: hello
 1: how are you
^C
Caught Ctrl + C. Exiting...
