Unit Pbhub v1.1 Arduino Tutorial
1. Preparations
2. Notes
Pin Compatibility
Since pin configurations vary across host devices, please refer to the Pin Compatibility Table in the product documentation before use, and modify the sample program according to your actual pin connections.
Pin Definition
This tutorial uses CoreS3 as the main controller paired with Unit Pbhub v1.1. This pin expansion module communicates via I2C. Modify pin definitions in the program according to actual circuit connections. The corresponding IOs after device connection are G2 (SDA) and G1 (SCL).
3. Analog Reading Experiment
  • Read analog voltage values from all six channels
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
#include "M5Unified.h"
#include "M5UnitPbHub.h"
M5UnitPbHub pbhub;
    M5.Display.fillScreen(WHITE);
    M5.Display.setCursor(0, 0);
    if (!pbhub.begin(&Wire, UNIT_PBHUB_I2C_ADDR, 2, 1, 400000U)) {
        Serial.println("Couldn't find Pbhub");
        while (1) delay(1);
    Serial.println("Pbhub v1.1 analog_read test");
    // ch: 0-5
    // index: 0-1
    // status: 0/1
    for (uint8_t ch = 0; ch < 6; ch++) {
        // only one pin supports analog reading each channel
        Serial.printf("ch:%d adc:%d\r\n", ch, pbhub.analogRead(ch));
        M5.Display.printf("ch:%d adc:%d\r\n", ch, pbhub.analogRead(ch));
        delay(500);
4. Pin Read/Write Experiment
  • Read the pin level status of different channels
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
M5UnitPbHub pbhub;
        while (1) delay(1);
    Serial.println("Pbhub v1.1 digital write read test");
    // ch: 0-5
    // index: 0-1
    // status: 0/1
        for (uint8_t index = 0; index < 2; index++) {
            pbhub.digitalWrite(ch, index, 1);
            delay(300);
            Serial.printf("ch:%d index:%d\r\n", pbhub.digitalRead(ch, index),
                          index);
            M5.Display.printf("ch:%d index:%d\r\n", pbhub.digitalRead(ch, index),
                          index);
            delay(300);
            pbhub.digitalWrite(ch, index, 0);
                          index);
                          index);
            delay(300);
5. Pin Duty Cycle Setting Experiment
  • Set and read duty cycles for different channel pins
M5UnitPbHub pbhub;
        while (1) delay(1);
    Serial.println("Pbhub v1.1 PWM test");
    // ch: 0-5
    // index: 0-1
    // status: 0/1
            for (uint8_t h = 0; h < 255; h++) {
                pbhub.setPWM(ch, index, h);
                Serial.printf("ch:%d index:%d PWM: %.1f%%\r\n", ch, index,
                              h / 255.0 * 100.0);
                M5.Display.printf("ch:%d index:%d PWM: %.1f%%\r\n", ch, index,
                              h / 255.0 * 100.0);
6. RGB Module Experiment
  • Connect external Unit RGB module for color display
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
M5UnitPbHub pbhub;
    if (!pbhub.begin(&Wire, UNIT_PBHUB_I2C_ADDR, 2, 1, 100000U)) {
        while (1) delay(1);
        pbhub.setLEDNum(ch, 74);
        pbhub.setLEDBrightness(ch, 40);
    // ch: 0-5
    // index: 0-1
    // status: 0/1
        pbhub.fillLEDColor(ch, 0, 73, 0xff0000);    // Red
        Serial.printf("ch:%d color:red\r\n", ch);
        M5.Display.printf("ch:%d color:red\r\n", ch);
        pbhub.fillLEDColor(ch, 0, 73, 0x00ff00);    // Green
        Serial.printf("ch:%d color:green\r\n", ch);
        M5.Display.printf("ch:%d color:green\r\n", ch);
        pbhub.fillLEDColor(ch, 0, 73, 0x0000ff);    // Blue
        Serial.printf("ch:%d color:blue\r\n", ch);
        M5.Display.printf("ch:%d color:blue\r\n", ch);
7. Servo Control Experiment
  • Control servo motor to rotate between 0°~90°
Circuit Connection
For servo connection: yellow wire is signal, red wire is 5V, brown wire is GND. Refer to the pinout diagram on the back of Unit Pbhub v1.1 when connecting.
M5UnitPbHub pbhub;
        while (1) delay(1);
    Serial.println("Pbhub v1.1 Servo test");
    // ch: 0-5
    // index: 0-1
    // status: 0/1
    for (uint8_t ch = 0; ch < 3; ch++) {
            pbhub.setServoAngle(ch, index, 90);
            Serial.printf("ch:%d index:%d Servo Angle: 90\r\n", ch, index);
            M5.Display.printf("ch:%d index:%d Servo Angle: 90\r\n", ch, index);
    delay(2000);
            pbhub.setServoAngle(ch, index, 0);
            Serial.printf("ch:%d index:%d Servo Angle: 0\r\n", ch, index);
            M5.Display.printf("ch:%d index:%d Servo Angle: 0\r\n", ch, index);
    delay(2000);
8. Compile and Upload
  • Download Mode: Different devices need to enter download mode before programming. This step may vary depending on the main controller. For details, refer to the device-specific programming tutorial list at the bottom of the Arduino IDE Getting Started Guide page.
  • For CoreS3: Press and hold the reset button (about 2 seconds) until the internal green LED lights up, then release. The device is now in download mode and ready for programming.
  • Select the device port and click the upload button in the top-left corner of Arduino IDE. Wait for the program to compile and upload to the device.
