StickC-Plus Button
read
Syntax:
uint8_t read();
Description:
  • Read Button status
Parameters:
  • null
Return:
  • uint8_t:
    • 1:Button Press
    • 0:Button Release
Example:
1 2 3 4 5 6 7 8 9 10 11
#include <M5StickCPlus.h>
  M5.Lcd.println("Please pressed Button A.");
  M5.Lcd.setCursor(0, 0);
  M5.Lcd.printf("Button A Status: %d ",M5.BtnA.read());
lastChange
Syntax:
uint32_t lastChange();
Description:
  • Get the time of the last status update
Parameters:
  • null
Return:
  • uint32_t: Time of last status update ms
Example:
1 2 3 4 5 6 7 8 9 10 11 12
  M5.Lcd.printf("The last change at %d ms /n",M5.BtnA.lastChange());
isPressed
Syntax:
uint8_t isPressed();
Description:
  • Determine if a Button is pressed
Parameters:
  • null
Return:
  • uint8_t:
    • 1: Button is pressed
    • 0: Button is not pressed
Example:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  if (M5.BtnA.isPressed()) {
    M5.Lcd.println("Button is Pressed.");
  }else{
    M5.Lcd.println("Button is Released.");
  delay(20);
wasPressed
Syntax:
uint8_t wasPressed();
Description:
  • Determine if a Button has changed from released to pressed.
Parameters:
  • null
Return:
  • uint8_t:
    • 1: Trigger Button to change from released to pressed state
    • 0: Untriggered Button changes from released state to pressed state
Example:
  if (M5.BtnA.wasPressed()) {
    M5.Lcd.println("Button is pressed.");
  delay(20);
pressedFor
Syntax:
uint8_t pressedFor(uint32_t ms);
Description:
  • Determine if a Button has been pressed for longer than the specified timeout period.
Parameters:
  • uint32_t ms:
    • Button press timeout ms
Return:
  • uint8_t:
    • 1: Trigger Button release beyond timeout
    • 0: non-triggered
Example:
  if (M5.BtnA.pressedFor(2000)) {
    M5.Lcd.println("Button A was pressed for more than 2 seconds.");
isReleased
Syntax:
Description:
  • Determine if a Button is in the released state
Parameters:
  • null
Return:
  • uint8_t:
    • 1: Button is released.
    • 0: Button are not released.
Example:
  if (M5.BtnA.isReleased()) {
    M5.Lcd.println("Button is released.");
  }else{
    M5.Lcd.println("Button is Pressed .");
  delay(20);
releasedFor
Syntax:
uint8_t releasedFor(uint32_t ms);
Description:
  • Determine Button release timeout
Parameters:
  • uint32_t ms:
    • Button release timeout ms
Return:
  • uint8_t:
    • 0: non-triggered
Example:
  if (M5.BtnA.releasedFor(2000)) {
    M5.Lcd.println("Button A was released for more than 2 seconds.");
  }else{
    M5.Lcd.println("Button A is pressed                           ");
wasReleased
Syntax:
uint8_t wasReleased();
Description:
  • Determine if a Button is pressed and released.
Parameters:
  • null
Return:
  • uint8_t:
    • 1: Trigger button changes from pressed state to released state
    • 0: Untriggered Button changes from pressed to released state
Example:
  if(M5.BtnA.wasReleased()) {
  delay(20);
wasReleasefor
Syntax:
uint8_t wasReleasefor(uint32_t ms);
Description:
  • Determine if a Button has been pressed for more than the specified timeout, and trigger when the Button is released.
Parameters:
  • uint32_t ms:
Return:
  • uint8_t:
    • 0: non-triggered
Example:
  if (M5.BtnA.wasReleasefor(3000)) {
      M5.Lcd.println("OK");
