Air Quality Battery Level Data Retrieval
Air Quality battery-level related API and example program.
Example
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
static constexpr int BAT_PIN        = 14;
static constexpr float VREF         = 3.3f;   // ADC reference voltage
static constexpr int ADC_RESOLUTION = 4095;   // 12-bit resolution (0–4095)
static constexpr float DIVIDER      = 2.0f;   // voltage divider ratio
  // initialize M5Unified
  analogSetPinAttenuation(BAT_PIN, ADC_11db);
  M5.Display.clear(TFT_BLACK);
  M5.Display.setTextSize(3);
  // read ADC once
  int raw = analogRead(BAT_PIN);
  // calculate voltage: raw/4095 * 3.3 * 2
  float vb = (raw / float(ADC_RESOLUTION)) * VREF * DIVIDER;
  // display the result on the screen
  M5.Display.setCursor(10, 20);
  M5.Display.printf("Battery:\n%.2f V", vb);
  // update every second
  delay(5000);
After uploading, you will see the following effect:
