Module Audio Arduino Tutorial
2. Initialization
Module Audio integrates an STM32 main controller to handle headset standard switching, LED control, headphone insertion detection (Channel 2 only), microphone input mode configuration, and other functions.
Interface Standard Selection
Since different headset wiring standards use different pin assignments, call device.setHPMode(AUDIO_HPMODE_NATIONAL); or device.setHPMode(AUDIO_HPMODE_AMERICAN); to switch between OMTP (AUDIO_HPMODE_NATIONAL) and CTIA (AUDIO_HPMODE_AMERICAN) for compatibility.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
#include "M5Unified.h"
#include "audio_i2c.hpp"
#include "es8388.hpp"
#include "driver/i2s.h"
#define SYS_I2C_SDA_PIN  21
#define SYS_I2C_SCL_PIN  22
#define SYS_I2S_MCLK_PIN 0
#define SYS_I2S_SCLK_PIN 19
#define SYS_I2S_LRCK_PIN 27
#define SYS_I2S_DOUT_PIN 2
#define SYS_I2S_DIN_PIN  34
#define SYS_SPI_MISO_PIN 38
#define SYS_SPI_MOSI_PIN 23
#define SYS_SPI_CLK_PIN  18
#define SYS_SPI_CS_PIN   4
AudioI2c device;
ES8388 es8388(&Wire, SYS_I2C_SDA_PIN, SYS_I2C_SCL_PIN);
    device.begin(&Wire, SYS_I2C_SDA_PIN, SYS_I2C_SCL_PIN);
    // device.setHPMode(AUDIO_HPMODE_AMERICAN);
    device.setMICStatus(AUDIO_MIC_OPEN);
    device.setRGBBrightness(100);
    for (int i = 0; i <= 2; i++) {
        device.setRGBLED(i, 0x0000ff);
    bool isHPInsert = device.getHPInsertStatus();
    if (isHPInsert) {
        Serial.println("Headphone Inserted");
        Serial.println("Headphone Removed");
    delay(500);
3. Input Interface Configuration
Interface Usage
Module Audio provides two sets of 3.5 mm audio jacks (Channel 1 and Channel 2): Channel 1 is for 3.5 mm TRS microphone input only; Channel 2 supports 3.5 mm TRRS combined audio I/O, and is also compatible with TRS jacks.
  • TRS jack wiring: connect Channel 1 to MIC input and Channel 2 to audio output. Suitable for devices with separate mic and audio output (e.g., PC headsets).
  • TRRS jack wiring: connect Channel 2 for combined audio I/O. Suitable for wired headsets with built-in mics, and compatible with TRS devices.
After initialization, call the following APIs to select ADC/DAC channels and set volume/gain:
// Use input 1 for both channels
es8388.setADCInput(ADC_INPUT_LINPUT1_RINPUT1);
// Use input 2 for both channels
// es8388.setADCInput(ADC_INPUT_LINPUT2_RINPUT2);
es8388.setDACOutput(DAC_OUTPUT_OUT1);
es8388.setADCVolume(100);
es8388.setDACVolume(40);
es8388.setMicGain(MIC_GAIN_24DB);
es8388.setBitsSample(ES_MODULE_ADC, BIT_LENGTH_16BITS);
es8388.setSampleRate(SAMPLE_RATE_44K);
4. Recording & Playback
Using the TRS wiring method, configure Channel 1 for MIC input and Channel 2 for audio output to read MIC input data in real time and play it back.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
AudioI2c device;
uint16_t rxbuf[256], txbuf[256];
size_t readsize = 0;
i2s_config_t i2s_config = {
    .mode                 = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_RX),
    .sample_rate          = 44100,
    .bits_per_sample      = I2S_BITS_PER_SAMPLE_16BIT,
    .channel_format       = I2S_CHANNEL_FMT_RIGHT_LEFT,
    .communication_format = I2S_COMM_FORMAT_STAND_I2S,
    .intr_alloc_flags     = 0,
    .dma_buf_count        = 8,
    .dma_buf_len          = 512,
    .use_apll             = false,
    .tx_desc_auto_clear   = true,
    .fixed_mclk           = 0
i2s_pin_config_t pin_config = {
    .mck_io_num   = SYS_I2S_MCLK_PIN,
    .bck_io_num   = SYS_I2S_SCLK_PIN,
    .ws_io_num    = SYS_I2S_LRCK_PIN,
    .data_out_num = SYS_I2S_DOUT_PIN,
    .data_in_num  = SYS_I2S_DIN_PIN,
    // Initialize ES8388
    if (!es8388.init()) Serial.println("Init Fail");
    // Install I2S driver
    i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
    i2s_set_pin(I2S_NUM_0, &pin_config);
    i2s_read(I2S_NUM_0, &rxbuf[0], 256 * 2, &readsize, portMAX_DELAY);
    for (int i = 0; i < 256; i++) {
        txbuf[i] = rxbuf[i];
    i2s_write(I2S_NUM_0, &txbuf[0], 256 * 2, &readsize, portMAX_DELAY);
5. Playing microSD WAV
Configure Channel 2 for audio output, load a WAV file from the microSD card, and play it. Ensure the WAV file is copied to the microSD card and the card is inserted into the host device.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75
#include <SPI.h>
#include <SD.h>
AudioI2c device;
void i2s_write_task(void *arg);
i2s_config_t i2s_config = { /* same as above */ };
i2s_pin_config_t pin_config = { /* same as above */ };
    es8388.setDACVolume(80);
    if (SD.begin(SYS_SPI_CS_PIN)) {
        Serial.println("SD card initialized successfully");
        Serial.println("Failed to initialize SD card. Retrying...");
    xTaskCreate(i2s_write_task, "i2s_write_task", 1024 * 8, NULL, 6, NULL);
void loop() { }
    File file = SD.open("/hello.wav", FILE_READ);
    if (!file) {
        Serial.println("Failed to open WAV file for reading");
        vTaskDelete(NULL);
    file.seek(44); // Skip WAV header
    uint8_t buf[1024];
    size_t bytesRead, bytesWritten;
    while (true) {
        if (file.available() == 0) {
            file.seek(44);
        bytesRead = file.read(buf, sizeof(buf));
        if (bytesRead > 0) {
            esp_err_t res = i2s_write(I2S_NUM_0, buf, bytesRead, &bytesWritten, portMAX_DELAY);
            if (res != ESP_OK) {
                Serial.printf("I2S write error: %d\n", res);
            break;
    file.close();
    vTaskDelete(NULL);
6. RGB LED Control
Module Audio integrates three programmable RGB LEDs on its side. Refer to the example below for control.
AudioI2c device;
    while (!device.begin(&Wire, SYS_I2C_SDA_PIN, SYS_I2C_SCL_PIN)) {
        device.setRGBLED(i, 0xff0000);
        device.setRGBLED(i, 0x00ff00);
