UiFlow Tutorial
UiFlow1 Development Guide
Project Management
Use LTE network
UiFlow1 Blockly
Event
Unit
Unit RS485-ISO
Example
The device sends and receives data
from m5stack import *
from m5stack_ui import *
from uiflow import *
import unit
screen = M5Screen()
screen.clean_screen()
screen.set_screen_bg_color(0xFFFFFF)
RS485_0 = unit.get(unit.RS485, unit.PORTC)
RS485_0.init(1, baudrate=9600, data_bits=8, stop_bits=1, parity=None, ctrl_pin=None)
while True:
  RS485_0.write('hello'+"\r\n")
  print((str('data:') + str((RS485_0.read()))))
  wait_ms(2)
API
  • Initialize UART communication
print(RS485_0.any())
  • Retain cached data
print(RS485_0.read())
  • Read all data
print(RS485_0.readline())
  • Get characters read line by line
print(RS485_0.read(10))
  • Read characters
print((str('coils:') + str((RS485_0.read_coils(1, 1, 0)))))
  • Read coil status
print((str('discrete:') + str((RS485_0.read_discrete_inputs(1, 1, 0)))))
  • Read discrete inputs
print((str('holding:') + str((RS485_0.read_holding_registers(1, 1, 0, True)))))
  • Read holding registers
print((str('input:') + str((RS485_0.read_discrete_inputs(1, 1, 0)))))
  • Read input registers
RS485_0.write('')
  • Write data
RS485_0.write(''+"\r\n")
-Write data line by line
print((str('write multiple coils:') + str((RS485_0.write_multiple_coils(1, 1, 0)))))
  • Write multiple coils
print((str('write multiple register:') + str((RS485_0.write_multiple_registers(1, 1, 0, True)))))
  • Write multiple registers
RS485_0.write(bytes([0, 0, 0]))
  • Write raw data
print((str('write single coil:') + str((RS485_0.write_single_coil(1, 1, 0)))))
  • Write single coil
print((str('write single register:') + str((RS485_0.write_single_register(1, 1, 0, True)))))
  • Write single register
