产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
Real-ESRGAN
Real-ESRGAN 是一种基于深度学习的图像超分辨率模型,能够在恢复低分辨率图像细节的同时有效去除噪声,适用于图像和视频的清晰化处理。
提示
git clone https://huggingface.co/AXERA-TECH/Real-ESRGAN
文件说明:
m5stack@raspberrypi:~/rsp/Real-ESRGAN $ ls -lh
total 428K
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 13 09:12 ax630c
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 13 09:12 ax650
-rw-rw-r-- 1 m5stack m5stack    0 Aug 13 09:11 config.json
-rw-rw-r-- 1 m5stack m5stack 2.9K Aug 13 09:11 main.py
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 13 09:12 onnx
-rw-rw-r-- 1 m5stack m5stack 387K Aug 13 09:12 output_test_256.jpg
-rw-rw-r-- 1 m5stack m5stack 3.9K Aug 13 09:11 README.md
-rw-rw-r-- 1 m5stack m5stack  19K Aug 13 09:11 test_256.jpeg
  1. 创建虚拟环境
python -m venv esrgan
  1. 激活虚拟环境
source esrgan/bin/activate
  1. 安装依赖包
pip install argparse numpy opencv-python
  1. 运行
python3 main.py --input test_256.jpeg --output test_256_20e.jpeg --model ax650/realesrgan-x4-256.axmodel
运行结果:
(esrgan) m5stack@raspberrypi:~/rsp/Real-ESRGAN $ python3 main.py --input test_256.jpeg --output test_256_20e.jpeg --model ax650/realesrgan-x4-256.axmodel
[INFO] SOC Name: AX650N
[INFO] Compiler version: 3.4 3dfd5692
input.1 [1, 256, 256, 3] uint8
1895 [1, 1024, 1024, 3] float32
Original Image Shape: (243, 243, 3)
Preprocessed Image Shape: (1, 256, 256, 3)
Inference Time: 454.03 ms
Output Shape: (1, 1024, 1024, 3)
Final Output Image Shape: (1024, 1024, 3)
原图:
输出:
