Burn to device in the interface to start flashing the UiFlow2 firmware.
Select COM.
Connect.
When the interface displays Connected to xxx, the port is connected successfully.
Burn, then click Start in the pop-up window.
Next.
When Burn successfully is displayed, flashing is successful. Please reset the device at this point.
Configuration, and modify the settings according to the on-screen instructions.
Chain Captain supports connecting to UiFlow2 via Access Code (wireless network) or USB (wired connection to a computer) for program pushing and debugging. Refer to the following tutorial:
Configuration on the firmware flashing page, update the configuration, and flash the firmware again.
Access Code on the device's UiFlow2 startup screen.
Visit uiflow2.m5stack.com to open the UiFlow2 Web IDE.
Click Select Your Controller on the page (shown on first entry) or the Controller button to enter the Select Device page.
Connect Device, enter the Access Code and a custom device name, then click Confirm to connect Chain Captain to UiFlow2.
Select Device page, select the connected Chain Captain device, then click Confirm to enter the UiFlow2 programming interface.
Confirm.
WebTerminal button, select the serial port for Chain Captain in the dialog, and click Connect.
When the WebTerminal screen displays Connected to Serial Port!, the USB connection is successful.
After the device is connected to UiFlow2, you can edit programs by dragging Blockly blocks.
After editing the program, click the Run Once button in the lower-right corner to run the program once for testing. Click Run Always to download the program to the device.
You can also run the program once or download it in the WebTerminal window.
