Arduino 上手教程
2. 设备开发 & 案例程序
5. 拓展模块
6. 应用案例
Chain Buzzer 使用教程
1.准备工作
  • 环境配置:参考 Arduino IDE 上手教程 完成 IDE 安装,并根据实际使用的开发板安装对应的板管理与需要的驱动库。
  • 使用到的驱动库:
2.示例程序
编译要求
M5Stack 板管理版本 >= 3.2.4
M5Chain 库版本 >= 1.0.8
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72
#include "M5Chain.h"
#define RXD_PIN GPIO_NUM_5  // 47 for the other side of Chain DualKey
#define TXD_PIN GPIO_NUM_6  // 48 for the other side of Chain DualKey
Chain M5Chain;
uint16_t device_count = 0;
uint8_t opr_status = 0;
uint8_t buzzer_id = 0;
bool buzzer_found = false;
  Serial.println("M5Stack Chain Buzzer Test");
  for (uint16_t i = 0; i < device_count; i++) {
    if (device_list->devices[i].device_type == CHAIN_BUZZER_TYPE_CODE) {
      buzzer_id = device_list->devices[i].id;
      buzzer_found = true;
      Serial.printf("ID[%d] is Chain Buzzer\n", buzzer_id);
      break;
  if (!buzzer_found) {
    Serial.println("Chain Buzzer not found");
    return;
  // Device ID, RGB brightness (0-100), operation status pointer
  M5Chain.setRGBLight(buzzer_id, 50, &opr_status);
  // Device ID, buzzer mode, operation status pointer
  M5Chain.setBuzzerMode(buzzer_id, BUZZER_MODE_AUTO_PLAY, &opr_status);
    return;
  uint8_t red[] = {255, 0, 0};
  M5Chain.setRGBValue(buzzer_id, 0, 1, red, sizeof(red), &opr_status);
  // Device ID, frequency (100-10000 Hz), duty (0-100%), duration (ms),
  // operation status pointer
  M5Chain.setBuzzerAutoPlay(buzzer_id, 1000, 50, 500, &opr_status);
  Serial.println("Buzzer: 1000 Hz, 50%, 500 ms");
  uint8_t blue[] = {0, 0, 255};
  M5Chain.setRGBValue(buzzer_id, 0, 1, blue, sizeof(blue), &opr_status);
  M5Chain.setBuzzerAutoPlay(buzzer_id, 2000, 50, 500, &opr_status);
  Serial.println("Buzzer: 2000 Hz, 50%, 500 ms");
用 Chain Bridge 连接器连接主控 Chain DualKey 和 Chain Buzzer。连接时需要注意方向,三角箭头从主控 Chain DualKey 指向外侧,如图:
IO 引脚配置
RXD_PIN = GPIO_NUM_5(GPIO5)
TXD_PIN = GPIO_NUM_6(GPIO6)
本案例使用 Chain DualKey 的 GPIO5 作为 RX、GPIO6 作为 TX。若将 Chain Buzzer 连接到 Chain DualKey 的另一侧接口,或改用其他主控设备,请根据实际接线修改程序中的 RXD_PIN 和 TXD_PIN。
将以上程序编译并上传至设备,点击 Arduino IDE 右上角的按钮打开串口监视器(Serial Monitor)。可以看到当前播放的蜂鸣器频率、占空比和持续时间。Chain Buzzer 会在红灯和蓝灯之间切换,并交替播放 1000 Hz 和 2000 Hz 的提示音:
例程效果如下:
3.参考链接
