产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
LivePortrait
LivePortrait 是一种基于深度学习的人像驱动生成模型,可将静态人像转换为具有真实表情与动作的动态视频效果。
提示
git clone https://huggingface.co/AXERA-TECH/LivePortrait
文件说明:
m5stack@raspberrypi:~/rsp/LivePortrait $ ls -lh
total 16K
drwxrwxr-x 3 m5stack m5stack 4.0K Aug 13 09:41 assets
-rw-rw-r-- 1 m5stack m5stack    0 Aug 13 09:41 config.json
drwxrwxr-x 5 m5stack m5stack 4.0K Aug 13 09:41 python
-rw-rw-r-- 1 m5stack m5stack 5.7K Aug 13 09:41 README.md
  1. 创建虚拟环境
python -m venv lvpr
  1. 激活虚拟环境
source lvpr/bin/activate
  1. 安装依赖包
pip install -r python/requirements.txt
pip install requests tqdm
运行:
python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d8.jpg --models ./python/axmodels/ --output-dir ./axmodel_infer
运行结果:
(lvpr) m5stack@raspberrypi:~/rsp/LivePortrait $ python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d8.jpg --models ./python/axmodels/ --output-dir ./axmodel_infer
[INFO] SOC Name: AX650N
[INFO] Compiler version: 3.3 144960ad
[INFO] Compiler version: 3.3 0f7260e8
FaceAnalysisDIY warmup time: 0.237s
LandmarkRunner warmup time: 0.183s
2025-08-13 10:04:42.914 | INFO     | __main__:main:727 - Start making driving motion template...
2025-08-13 10:04:43.782 | INFO     | __main__:main:747 - Prepared pasteback mask done.
2025-08-13 10:04:44.565 | INFO     | __main__:main:787 - The output of image-driven portrait animation is an image.
2025-08-13 10:04:50.566 | DEBUG    | __main__:warp_decode:647 - warp time: 5.997s
2025-08-13 10:04:50.902 | INFO     | __main__:main:881 - Animated image: ./axmodel_infer/s0--d8.jpg
2025-08-13 10:04:50.902 | INFO     | __main__:main:882 - Animated image with concat: ./axmodel_infer/s0--d8_concat.jpg
2025-08-13 10:04:50.920 | DEBUG    | __main__:<module>:894 - LivePortrait axmodel infer time: 18.068s
原图:
输出:
Video
运行:
python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d0.mp4 --models ./python/axmodels/ --output-dir ./axmodel_infer
运行结果:
(lvpr) m5stack@raspberrypi:~/rsp/LivePortrait $ python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d0.mp4 --models ./python/axmodels/ --output-dir ./axmodel_infer
FaceAnalysisDIY warmup time: 0.213s
LandmarkRunner warmup time: 0.180s
2025-08-13 10:14:47.779 | INFO     | __main__:main:727 - Start making driving motion template...
2025-08-13 10:15:04.110 | INFO     | __main__:main:747 - Prepared pasteback mask done.
2025-08-13 10:15:04.903 | INFO     | __main__:main:785 - The animated video consists of 78 frames.
2025-08-13 10:15:11.468 | DEBUG    | __main__:warp_decode:647 - warp time: 6.561s
2025-08-13 10:25:50.630 | DEBUG    | __main__:warp_decode:647 - warp time: 8.343s
2025-08-13 10:25:51.493 | INFO     | __main__:has_audio_stream:114 - Error occurred while probing video: ./assets/examples/driving/d0.mp4, you may need to install ffprobe! (https://ffmpeg.org/download.html) Now set audio to false!
2025-08-13 10:25:54.608 | INFO     | __main__:main:870 - Animated video: ./axmodel_infer/s0--d0.mp4
2025-08-13 10:25:54.609 | INFO     | __main__:main:871 - Animated video with concat: ./axmodel_infer/s0--d0_concat.mp4
2025-08-13 10:25:54.644 | DEBUG    | __main__:<module>:894 - LivePortrait axmodel infer time: 670.930s
原视频:
输出:
