产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
RIFE
RIFE 是一种基于深度学习的实时视频插帧模型,能够高效预测中间帧以提升视频帧率,适用于视频流畅化与动画制作等领域。
提示
git clone https://huggingface.co/AXERA-TECH/RIFE.axera
文件说明:
m5stack@raspberrypi:~/rsp/RIFE.axera $ ls -lh
total 52K
-rw-rw-r-- 1 m5stack m5stack 1.1K Sep 29 14:28 build_config.json
-rw-rw-r-- 1 m5stack m5stack    0 Sep 29 14:28 config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Sep 29 14:28 model
-rw-rw-r-- 1 m5stack m5stack 6.9K Sep 29 14:28 ms_ssim.py
-rw-rw-r-- 1 m5stack m5stack 1.8K Sep 29 14:28 README.md
-rw-rw-r-- 1 m5stack m5stack   88 Sep 29 14:28 requirements.txt
-rw-rw-r-- 1 m5stack m5stack 9.2K Sep 29 14:28 run_axmodel.py
-rw-rw-r-- 1 m5stack m5stack 9.2K Sep 29 14:28 run_onnx.py
drwxrwxr-x 2 m5stack m5stack 4.0K Sep 29 14:28 video
  1. 创建虚拟环境
python -m venv rife
  1. 激活虚拟环境
source rife/bin/activate
  1. 安装依赖包
  1. 运行
python3 run_axmodel.py --model ./model/rife_x2_720p.axmodel --video ./video/demo.mp4
运行结果:
(rife) m5stack@raspberrypi:~/rsp/RIFE.axera $ python3 run_axmodel.py --model ./model/rife_x2_720p.axmodel --video ./video/demo.mp4
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 77cdc0c2
./video/demo.mp4, 128.0 frames in total, 25.0FPS to 50.0FPS
The audio will be merged after interpolation process
 99%|██████████████████████████████████████▋| 127/128.0 [02:45<00:01,  1.30s/it]
