Unit DLight Arduino Tutorial
2. Notes
Pin Compatibility
Pin configurations vary between host devices. M5Stack provides an official pin compatibility table for reference. Modify the example program according to the actual pin connections.
3. Example Program
  • This tutorial uses Basic V2.7 with Unit DLight. Unit DLight communicates via I2C at the default address 0x23. Once connected, the corresponding pins are G21 (SDA) and G22 (SCL).
Unit DLight integrates a BH1750FVI illuminance sensor and supports illuminance detection from 1 ~ 65535 lx. This example uses continuous high-resolution mode to measure ambient light illuminance.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
#include <M5_DLight.h>
M5Canvas canvas(&M5.Display);
M5_DLight sensor;
uint16_t lux;
    canvas.setTextDatum(MC_DATUM);
    canvas.setColorDepth(1);
    canvas.setFont(&fonts::Orbitron_Light_24);
    canvas.setTextSize(2);
    canvas.setPaletteColor(1, ORANGE);
    Serial.println("Sensor begin.....");
    sensor.begin(&Wire, SDA, SCL);
    // CONTINUOUSLY_H_RESOLUTION_MODE
    // CONTINUOUSLY_H_RESOLUTION_MODE2
    // CONTINUOUSLY_L_RESOLUTION_MODE
    // ONE_TIME_H_RESOLUTION_MODE
    // ONE_TIME_H_RESOLUTION_MODE2
    // ONE_TIME_L_RESOLUTION_MODE
    sensor.setMode(CONTINUOUSLY_H_RESOLUTION_MODE);
char info[40];
    lux = sensor.getLUX();
    sprintf(info, "lux: %d", lux);
    canvas.fillSprite(BLACK);
    canvas.drawString(info, 160, 120);
    canvas.pushSprite(0, 0);
    Serial.println(info);
    delay(100);
4. Compile and Upload
  • Copy and paste the example code above into the project code area and select the device port. For details, see Program Compilation and Flashing. Click the compile and upload button in the upper-left corner of Arduino IDE, then wait for the program to compile and upload to the device.
5. Ambient Light Illuminance Detection
  • After the program starts, the screen and Serial Monitor update the ambient light illuminance measured by Unit DLight every 100ms, displayed in lx. Change the light intensity on the sensor surface to observe changes in the illuminance value.
