Unit Mini Scales Arduino Tutorial
2. Notes
Pin Compatibility
Pin configurations vary between host devices. M5Stack provides an official pin compatibility table for reference. Modify the example program according to the actual pin connections.
3. Example Program
  • This tutorial uses CoreS3 with Unit Mini Scales. Unit Mini Scales communicates via I2C. Once connected, the corresponding pins are G2 (SDA) and G1 (SCL).
Caution
Install the weighing plate on Unit Mini Scales before use. The maximum weighing capacity is 5kg. To avoid damaging the sensor, do not exceed the rated capacity. Zero calibration or taring is recommended before the first measurement.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
#include <M5GFX.h>
#include "UNIT_SCALES.h"
M5Canvas canvas(&M5.Lcd);
UNIT_SCALES scales;
    M5.Lcd.begin();
    canvas.setFont(&fonts::FreeMonoBold12pt7b);
    canvas.createSprite(M5.Lcd.width(), M5.Lcd.height());
    // Initialize PORT.A I2C and retry until the unit responds.
    Wire.begin();
    while (!scales.begin(&Wire, EX_SDA, EX_SCL, DEVICE_DEFAULT_ADDR)) {
        Serial.println("Unit Mini Scales connect error");
        M5.Lcd.print("Unit Mini Scales connect error");
    // Set the unit status LED to dim green.
    scales.setLEDColor(0x001000);
    float weight = scales.getWeight();
    float gap    = scales.getGapValue();
    int adc      = scales.getRawADC();
    // Redraw the weight and raw ADC values.
    canvas.fillSprite(BLACK);
    canvas.drawCenterString("Unit Mini Scale Test", 160, 10);
    canvas.setTextColor(WHITE);
    canvas.setCursor(10, 50);
    canvas.printf("WEIGHT:");
    canvas.setTextColor(GREEN);
    canvas.printf("%.2fg", weight);
    canvas.setCursor(10, 100);
    canvas.printf("ADC:");
    canvas.printf("%d", adc);
    canvas.setTextColor(ORANGE);
    canvas.drawCenterString("Touch Screen to Offset", 160, 200);
    canvas.pushSprite(0, 0);
    // Tap the screen to use the current load as the zero offset.
    if (M5.Touch.getDetail().wasClicked()) {
        scales.setOffset();
4. Compile and Upload
  • Copy and paste the example code above into the project code area and select the device port. For details, see Program Compilation and Flashing. Click the compile and upload button in the upper-left corner of Arduino IDE, then wait for the program to compile and upload to the device.
5. Weighing and Zeroing
  • After Unit Mini Scales connects successfully, its status LED lights dim green, while the CoreS3 screen continuously displays the current weight and raw ADC value. Tap anywhere on the screen to call setOffset() and set the current load as zero. After taring, place an object on or remove it from the weighing plate to observe changes in the weight and ADC values.
