Input & Output Devices
Audio Playback Devices
DEIMv2
Tip
If git lfs has not been installed, refer to git lfs installation guide for installation.
git clone https://huggingface.co/AXERA-TECH/DEIMv2
File description:
m5stack@raspberrypi:~/rsp/DEIMv2 $ ls -lh
total 19M
-rw-rw-r-- 1 m5stack m5stack 8.9K Nov 10 10:11 axmodel_inf.py
-rw-rw-r-- 1 m5stack m5stack    0 Nov 10 10:11 config.json
-rw-rw-r-- 1 m5stack m5stack  18M Nov 10 10:11 deimv2_dinov3_s_coco.axmodel
-rw-rw-r-- 1 m5stack m5stack  87K Nov 10 10:11 onboard_result.jpg
-rw-rw-r-- 1 m5stack m5stack 261K Nov 10 10:11 people.jpg
-rw-rw-r-- 1 m5stack m5stack  888 Nov 10 10:11 README.md
python -m venv deim
source deim/bin/activate
  1. Install dependencies
pip install opencv-python torch torchvision
  1. Run
python3 axmodel_inf.py --axmodel deimv2_dinov3_s_coco.axmodel --input people.jpg -ms n
Run result:
(deim) m5stack@raspberrypi:~/rsp/DEIMv2 $ python3 axmodel_inf.py --axmodel deimv2_dinov3_s_coco.axmodel --input people.jpg -ms n
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 8a28aa57
Image processing complete. Result saved as 'result.jpg'.
Original image:
Output:
