#include <M5UNIT_DIGI_CLOCK.h>
constexpr uint8_t DIGI_ADDRESS = M5UNIT_DIGI_CLOCK_DEFAULT_ADDR;
constexpr uint8_t BRIGHTNESS = 8;
constexpr uint16_t UI_BG = 0x1082;
constexpr uint16_t UI_PANEL = 0x2104;
constexpr uint16_t UI_HEADER = 0x0349;
constexpr uint16_t UI_MUTED = 0xBDF7;
M5UNIT_DIGI_CLOCK digiClock;
M5Canvas canvas(&M5.Display);
uint32_t last_update = 0;
uint16_t minute_value = 0;
void drawCard(int16_t x, const char* label, const char* value, uint16_t value_color)
canvas.fillRoundRect(x, 148, 142, 50, 5, UI_PANEL);
canvas.drawRoundRect(x, 148, 142, 50, 5, UI_MUTED);
canvas.setTextDatum(textdatum_t::middle_left);
canvas.setFont(&fonts::Font2);
canvas.setTextSize(1);
canvas.setTextColor(UI_MUTED, UI_PANEL);
canvas.drawString(label, x + 10, 162);
canvas.setTextColor(value_color, UI_PANEL);
canvas.drawString(value, x + 10, 183);
void drawStatus(const char* value)
char brightness[8] = {};
snprintf(brightness, sizeof(brightness), "%u / 8",
static_cast<unsigned>(BRIGHTNESS));
canvas.fillScreen(UI_BG);
canvas.fillRect(0, 0, 320, 42, UI_HEADER);
canvas.setTextDatum(textdatum_t::middle_center);
canvas.setFont(&fonts::Font4);
canvas.setTextColor(TFT_WHITE, UI_HEADER);
canvas.drawString("UNIT DIGICLOCK", 160, 16);
canvas.setTextColor(UI_MUTED, UI_HEADER);
canvas.drawString("DIGITAL TIME / STATUS", 160, 33);
canvas.fillRoundRect(12, 54, 296, 78, 6, UI_PANEL);
canvas.drawRoundRect(12, 54, 296, 78, 6, TFT_CYAN);
canvas.drawString("DISPLAY VALUE", 160, 70);
canvas.setTextColor(TFT_CYAN, UI_PANEL);
canvas.drawString(value, 160, 101);
drawCard(12, "MODE", "CLOCK", TFT_WHITE);
drawCard(166, "BRIGHTNESS", brightness, TFT_ORANGE);
canvas.fillRect(0, 214, 320, 26, UI_HEADER);
canvas.drawString("RUNNING | UPDATE EVERY 1 s", 160, 227);
canvas.pushSprite(0, 0);
auto cfg = M5.config();
M5.begin(cfg);
canvas.setColorDepth(16);
canvas.createSprite(320, 240);
const int sda = M5.getPin(m5::pin_name_t::port_a_sda);
const int scl = M5.getPin(m5::pin_name_t::port_a_scl);
if (!digiClock.begin(&Wire, sda, scl, DIGI_ADDRESS)) {
drawStatus("----");
while (true) {
digiClock.setBrightness(BRIGHTNESS);
char blank[] = "----";
digiClock.setString(blank);
drawStatus("----");
if (millis() - last_update < 1000) {
return;
last_update = millis();
char value[6] = {};
snprintf(value, sizeof(value), "%02u:%02u",
static_cast<unsigned>(minute_value / 60),
static_cast<unsigned>(minute_value % 60));
digiClock.setString(value);
Serial.printf("DigiClock: %s\n", value);
drawStatus(value);
minute_value = (minute_value + 1) % (24 * 60);
