#include <M5UnitUnified.h>
#include <M5UnitUnifiedFLASHLIGHT.h>
using namespace m5::unit::aw3641e;
constexpr uint16_t UI_BG = 0x1082;
constexpr uint16_t UI_PANEL = 0x2104;
constexpr uint16_t UI_HEADER = 0x0349;
constexpr uint16_t UI_MUTED = 0xBDF7;
constexpr uint8_t TORCH_BRIGHTNESS = 10;
constexpr uint32_t PWM_FREQUENCY = 1000;
constexpr uint8_t PWM_RESOLUTION = 8;
constexpr uint8_t PWM_DUTY = (256u * TORCH_BRIGHTNESS + 50u) / 100u;
constexpr uint8_t PWM_CHANNEL = 7;
m5::unit::UnitUnified units;
m5::unit::UnitFlashLight unit;
M5Canvas canvas(&M5.Display);
int torch_pin = -1;
bool configureTorchPwm()
#if defined(ESP_ARDUINO_VERSION_MAJOR) && ESP_ARDUINO_VERSION_MAJOR >= 3
if (!ledcAttach(torch_pin, PWM_FREQUENCY, PWM_RESOLUTION)) {
return false;
ledcWrite(torch_pin, PWM_DUTY);
#else
if (ledcSetup(PWM_CHANNEL, PWM_FREQUENCY, PWM_RESOLUTION) == 0) {
return false;
ledcAttachPin(torch_pin, PWM_CHANNEL);
ledcWrite(PWM_CHANNEL, PWM_DUTY);
#endif
return true;
void drawStatus(const char* state)
const unsigned percent = TORCH_BRIGHTNESS;
char brightness[8] = {};
snprintf(brightness, sizeof(brightness), "%u%%", percent);
canvas.fillScreen(UI_BG);
canvas.fillRect(0, 0, 320, 42, UI_HEADER);
canvas.setTextDatum(textdatum_t::middle_center);
canvas.setFont(&fonts::Font4);
canvas.setTextSize(1);
canvas.setTextColor(TFT_WHITE, UI_HEADER);
canvas.drawString("UNIT FLASHLIGHT", 160, 16);
canvas.setFont(&fonts::Font2);
canvas.setTextColor(UI_MUTED, UI_HEADER);
canvas.drawString("FLASHLIGHT / STATUS", 160, 33);
canvas.fillRoundRect(12, 54, 296, 42, 6, UI_PANEL);
canvas.drawRoundRect(12, 54, 296, 42, 6, TFT_ORANGE);
canvas.setTextDatum(textdatum_t::middle_left);
canvas.setTextColor(UI_MUTED, UI_PANEL);
canvas.drawString("MODE", 24, 75);
canvas.setTextColor(TFT_ORANGE, UI_PANEL);
canvas.drawString("TORCH", 88, 75);
canvas.setTextColor(TFT_WHITE, UI_PANEL);
canvas.drawString("ON", 205, 75);
canvas.fillRoundRect(12, 108, 296, 88, 6, UI_PANEL);
canvas.drawRoundRect(12, 108, 296, 88, 6, UI_MUTED);
canvas.drawString("BRIGHTNESS", 24, 124);
canvas.setTextColor(TFT_YELLOW, UI_PANEL);
canvas.drawString(brightness, 160, 140);
canvas.fillRoundRect(54, 160, 212, 14, 4, UI_BG);
canvas.fillRoundRect(54, 160, 212 * percent / 100, 14, 4, TFT_YELLOW);
canvas.drawString("1000 Hz PWM", 160, 185);
canvas.fillRect(0, 204, 320, 36, UI_HEADER);
canvas.drawString("STATE", 16, 222);
canvas.setTextColor(TFT_CYAN, UI_HEADER);
canvas.drawString(state, 82, 222);
canvas.drawString("CONTINUOUS", 206, 222);
canvas.pushSprite(0, 0);
canvas.setColorDepth(16);
canvas.createSprite(320, 240);
auto cfg = unit.config();
cfg.switch_position = SwitchPosition::Torch;
unit.config(cfg);
torch_pin = M5.getPin(m5::pin_name_t::port_b_pin2);
if (!units.add(unit, -1, torch_pin) || !units.begin() ||
!configureTorchPwm()) {
drawStatus("ERROR");
while (true) {
drawStatus("Torch 10%");
units.update();
