Unit ACSSR/DCSSR Arduino Tutorial
2. Working Mode
Working Mode Configuration
Please refer to the following flowchart to configure the working mode before use
  • 1.With the device powered off, press and hold the middle button.
  • 2.Power on the device. When the device RGB LED flashes rapidly, it indicates it has entered mode configuration state.
  • 3.Click the button to switch modes:
    • Green light: Manual button mode. During operation, use the middle button to control the switch.
    • Red light: I2C communication mode. During operation, connect to the I2C bus via the HY2.0-4P Grove interface for control.
    • Yellow light: Modbus communication mode. During operation, connect to the Modbus bus via the HT3.96-4P interfaces on both ends of the device for control.
  • 4.Press and hold the button to select and save the current mode.
  • Load wiring sample diagram
3. I2C Mode Control
After configuring the device into I2C working mode, connect it to the I2C bus via the HY2.0-4P Grove interface for control. In this example, CoreS3 PORT.A is used for communication. When pairing with other controllers, please modify the program according to the actual connected pins.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
#include "M5Unified.h"
#include "M5_ACSSR.h"
M5_ACSSR SSR;
void printStatus();
    while (!SSR.begin(&Wire, 2, 1, ACSSR_DEFAULT_ADDR)) {
        M5.Display.println("ACSSR I2C INIT ERROR");
        Serial.println("ACSSR I2C INIT ERROR");
    SSR.on();
    SSR.setLEDColor(0xff0000);
    printStatus();
    SSR.off();
    SSR.setLEDColor(0x00ff00);
    printStatus();
void printStatus()
    int relay   = SSR.status();
    int color   = SSR.getLEDColor();
    int version = SSR.getVersion();
    M5.Display.clear();
    M5.Display.setCursor(0, 0);
    M5.Display.println("I2C Mode Control");
    if (relay != -1) {
        Serial.printf("Relay: %s\n", relay ? "ON" : "OFF");
        M5.Display.printf("Relay: %s\n", relay ? "ON" : "OFF");
    if (color != -1) {
        Serial.printf("LED Color: 0x%04X\n", color);
        M5.Display.printf("LED Color: 0x%04X\n", color);
    if (version != -1) {
        Serial.printf("FW Version: 0x%04X\n", version);
        M5.Display.printf("FW Version: 0x%04X\n", version);
4. Modbus Mode Control
After configuring the device into Modbus working mode, connect it to the Modbus bus via the HT3.96-4P interfaces on both ends of the device for control. In this example, CoreS3 PORT.A with Unit RS485-ISO is used for RS485 communication.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113
#include <ArduinoModbus.h>
#include <ArduinoRS485.h>
RS485Class RS485(Serial2, 1, 2, -1, -1);
uint8_t slave_id = 0;
void relayOn();
void relayOff();
void setLedColor(uint16_t color);
int getRelayStatus();
int getLedColor();
int getFirmwareVersion();
void printStatus();
    delay(2000);
    Wire.end();
    ModbusRTUClient.begin(115200, SERIAL_8N1);
    slave_id = ACSSR_DEFAULT_SLAVE_ID;
    relayOn();
    setLedColor(0xF800);  // RED
    printStatus();
    relayOff();
    setLedColor(0x07E0);  // GREEN
    printStatus();
void relayOn()
    ModbusRTUClient.coilWrite(slave_id, ACSSR_RELAY_COIL_ADDR, 0xFF);
void relayOff()
    ModbusRTUClient.coilWrite(slave_id, ACSSR_RELAY_COIL_ADDR, 0x00);
    ModbusRTUClient.holdingRegisterWrite(slave_id, ACSSR_LED_HOLDING_ADDR, color);
    if (ModbusRTUClient.requestFrom(slave_id, COILS, ACSSR_RELAY_COIL_ADDR, 1)) {
        while (ModbusRTUClient.available()) {
            return ModbusRTUClient.read();
    return -1;
int getLedColor()
    if (ModbusRTUClient.requestFrom(slave_id, HOLDING_REGISTERS, ACSSR_LED_HOLDING_ADDR, 1)) {
    return -1;
    if (ModbusRTUClient.requestFrom(slave_id, HOLDING_REGISTERS, ACSSR_VERSION_HOLDING_ADDR, 1)) {
    return -1;
void printStatus()
    int relay   = getRelayStatus();
    int color   = getLedColor();
    int version = getFirmwareVersion();
    M5.Display.clear();
    M5.Display.println("Modbus Mode Control");
    if (relay != -1) {
    if (color != -1) {
