M5GO Arduino Program Compilation & Upload
  • 3.Library Installation: Refer to the Library Management Installation Guide to complete the installation of the M5Unified and M5GFX driver libraries, and follow the prompts to install all the required libraries.
2.USB Driver Installation
Driver Installation Tip
Click the link below to download the driver matching your operating system. There are currently two versions of the driver chip, CP210X (for the CP2104 version) and CP34X (for the CH9102 version). After unzipping the package, select the installation package corresponding to your operating system and proceed with the installation. (If you are unsure which USB chip your device uses, you can install both drivers. CH9102_VCP_SER_MacOS v1.7 may show an error during installation, but it has actually completed successfully, so you can ignore the error.)
CP210x_VCP_Windows CP2104 Download
CP210x_VCP_MacOS CP2104 Download
CP210x_VCP_Linux CP2104 Download
3.Port Selection
Connect the device to the computer via a USB cable. After completing the driver installation, select the corresponding device port in the Arduino IDE.
4. Program Compile & Upload
Open the example program "LongTextScroll" in the driver library, click the upload button, and the program will be automatically compiled and uploaded.
The example program runs as follows:
5.Related Resources
