Unit Glass2 Arduino Tutorial
1.Preparation
2.Example Program
Compilation Requirements
M5Stack Board Package Version >= 3.2.2
M5Unified Library Version >= 0.2.7
M5GFX Library Version >= 0.2.9
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
#include <M5UnitGLASS2.h>
#define M5UNITGLASS2_ADDR 0x3C  // For Unit Glass2, 0x3C is default, and 0x3D is modified.
int index_unit_glass2;
  auto cfg = M5.config();
  cfg.external_display.unit_glass2 = true;
  M5.begin(cfg);
  index_unit_glass2 = M5.getDisplayIndex(m5::board_t::board_M5UnitGLASS2);
  M5.Displays(index_unit_glass2).setTextSize(2);
  M5.Displays(index_unit_glass2).clear();
  M5.Displays(index_unit_glass2).setCursor(0, 0);
  M5.Displays(index_unit_glass2).print("This is \nUnit \nGlass2");
  M5.Displays(index_unit_glass2).drawRect(0, 0, 128, 64, 0xFFFF);  // x, y, w, h, color
  delay(500);
  M5.Displays(index_unit_glass2).drawCircle(20, 20, 15, 0xFFFF);  // x, y, r, color
  delay(500);
  M5.Displays(index_unit_glass2).fillArc(50, 45, 17, 20, 100, 330, 0xFFFF);  // x, y, r0, r1, angle0, angle1, color
  delay(500);
  M5.Displays(index_unit_glass2).fillRect(45, 10, 25, 10, 0xFFFF);  // x, y, w, h, color
  delay(500);
  M5.Displays(index_unit_glass2).fillTriangle(90, 10, 80, 40, 110, 55, 0xFFFF);  // x0, y0, x1, y1, x2, y2, color
  delay(500);
  M5.Displays(index_unit_glass2).drawLine(110, 0, 128, 64, 0xFFFF);  // x0, y0, x1, y1, color
Runtime Effect:
3.I2C Address Modification
As shown in the image above, use a hex wrench to remove the two screws, then lift the cover plate upwards. Gently push aside the display ribbon cable to reveal the two semicircular solder pads inside the circle. Solder a bridge between the two pads to change the I2C address to 0x3D. To revert to the default address 0x3C, remove the solder bridge.
If the I2C address is changed to 0x3D, you need to add the macro definition #define M5UNITGLASS2_ADDR 0x3D in your program. The two HY2.0-4P Grove ports are interconnected and can be used interchangeably to connect other I2C devices.
4.API
