M5GO Button
M5GO button input related APIs and example program.
Note:
Include M5.update() function in the main loop to read status update and minimize blocking, otherwise you may not to be able to retrieve the status of key changes in time.
Example
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
#include "M5Unified.h"
    auto cfg = M5.config();
    M5.begin(cfg);
    if (M5.BtnA.wasPressed()) {
        Serial.println("BtnA Pressed");
    if (M5.BtnB.wasPressed()) {
        Serial.println("BtnB Pressed");
    if (M5.BtnC.wasPressed()) {
        Serial.println("BtnC Pressed");
For actual implementation results, download the example program, press the buttons, and open the serial monitor to see the output.
API
The button part of M5GO uses the Button_Class in the M5Unified library. For more related APIs, you can refer to the following document:
