Arduino Nesso N1 IR NEC
Arduino Nesso N1 IR driver example program. This example uses the Arduino-IRremote - Lib to implement NEC encoding.
Example Program
Compilation Requirements
  • M5Stack board manager version >= 3.2.5
  • Board option = ArduinoNessoN1
  • M5GFX library version >= 0.2.17
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
#define DISABLE_CODE_FOR_RECEIVER  // Disables restarting receiver after each
                                   // send. Saves 450 bytes of program memory and
                                   // 269 bytes of RAM if receiving functions are
                                   // not used.
#define SEND_PWM_BY_TIMER
#define IR_TX_PIN 9
#include "M5Unified.h"
#include <IRremote.hpp>  // include the library
// IRremote: https://github.com/Arduino-IRremote/Arduino-IRremote
uint8_t sCommand = 0x34;
uint8_t sRepeats = 0;
    auto cfg = M5.config();
    M5.begin(cfg);
    M5.Display.setRotation(1);
    M5.Display.setTextColor(GREEN);
    M5.Display.setTextFont(&fonts::Orbitron_Light_24);
    M5.Display.setTextSize(1);
    IrSender.begin(DISABLE_LED_FEEDBACK);  // Start with IR_SEND_PIN as send pin
    IrSender.setSendPin(IR_TX_PIN);
    Serial.println();
    Serial.print(F("Send now: address=0x1111, command=0x"));
    Serial.print(sCommand, HEX);
    Serial.print(F(", repeats="));
    Serial.print(sRepeats);
    Serial.println();
    M5.Display.clear();
    M5.Display.drawString("IR NEC SEND", M5.Display.width() / 2,
                                M5.Display.height() / 2 - 40);
    M5.Display.drawString("ADDR:0x1111", M5.Display.width() / 2,
                                M5.Display.height() / 2);
    M5.Display.drawString("CMD:0x" + String(sCommand, HEX),
                                M5.Display.height() / 2 + 40);
    Serial.println(F("Send standard NEC with 16-bit address"));
    M5.Display.fillCircle(32, 105, 8, GREEN);
    IrSender.sendNEC(0x1111, sCommand, sRepeats);
    // IrSender.sendOnkyo(0x1111, 0x2223, sRepeats);
     * Increment send values
    sCommand += 1;
    delay(500);
    M5.Display.fillCircle(32, 105, 8, YELLOW);
    delay(500);
