Environment Setup: Refer to the Arduino IDE Quick Start Tutorial to complete the IDE installation, and install the corresponding board manager and required driver libraries according to the development board you are using.
Required Libraries:
Hardware Used:
G26 (SCL) and G0 (SDA).#include "M5Unified.h"
#include "M5HatMiniEncoderC.h"
// MiniEncoderC I2C pins
#define MiniEncoderC_SDA 0
#define MiniEncoderC_SCL 26
M5HatMiniEncoderC encoder;
// Used to detect encoder value changes
int32_t lastEncoderValue = 0;
int32_t encoderIncValue = 0;
// Used to detect button state changes
bool lastEncoderBtnValue = 0;
// Wait until MiniEncoderC is ready
static void waitMiniEncoderCReady() {
while (!encoder.begin(&Wire, MiniEncoderC_ADDR, MiniEncoderC_SDA, MiniEncoderC_SCL, 100000UL)) {
delay(100);
M5.Display.setRotation(0);
M5.Display.fillScreen(BLACK);
// Initialize MiniEncoderC
waitMiniEncoderCReady();
// Reset encoder value to 0
encoder.setEncoderValue(0);
delay(100);
// Initial display
M5.Display.setCursor(0, 20);
M5.Display.printf("Val:%d", 0);
M5.Display.setCursor(0, 50);
M5.Display.printf("IncVal:%d", 0);
M5.Display.drawLine(0, 80, 135, 80, ORANGE);
M5.Display.setCursor(0, 90);
M5.Display.printf("BtnVal:1");
M5.Display.setCursor(0, 180);
M5.Display.printf("BtnA:\n Reset Cntr");
// Read encoder value
int32_t encoderValue = encoder.getEncoderValue();
// Read encoder button state
bool EncoderBtnValue = encoder.getButtonStatus();
// Only read increment value when encoder value changes
if (encoderValue != lastEncoderValue) {
encoderIncValue = encoder.getIncrementValue();
// Update encoder value display
M5.Display.fillRect(0, 20, 135, 50, BLACK);
M5.Display.setTextColor(WHITE, BLACK);
M5.Display.printf("Val: %d", encoderValue);
M5.Display.printf("IncVal: %d", encoderIncValue);
// Set LED color based on encoder value
uint8_t r = abs(encoderValue * 5) % 256;
uint8_t g = abs(encoderValue * 3) % 256;
uint8_t b = abs(encoderValue * 7) % 256;
uint32_t rgb888 = (r << 16) | (g << 8) | b;
encoder.setLEDColor(rgb888);
lastEncoderValue = encoderValue;
// Update display only when button state changes
if (EncoderBtnValue != lastEncoderBtnValue) {
M5.Display.fillRect(0, 90, 135, 80, BLACK);
M5.Display.printf("BtnVal: %d", EncoderBtnValue);
lastEncoderBtnValue = EncoderBtnValue;
if (M5.BtnA.wasPressed()) {
// Reset encoder value to 0 when BtnA is pressed
encoder.resetCounter();
delay(30);
