Unit PoE-P4 IR Transmit
Unit PoE-P4 IR transmit related libraries and example.
Example
Compilation Requirements
  • M5Stack Board Manager version >= 3.2.6
  • Development board option = M5UnitPoEP4
  • M5Unified library version >= 0.2.13
  • IRremote library version >= 4.5.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
#include <IRremote.hpp>
#define IR_SEND_PIN    14
// Demo parameters for NEC protocol
uint16_t address = 0x0000;     // Starting device address
uint8_t  command = 0x55;       // Starting command value
uint8_t  repeats = 0;          // Number of repeat transmissions
    M5.begin();                // Initialize M5Stack device
    Serial.begin(115200);      // Start serial communication at 115200 baud
    delay(200);                // Wait for serial port to stabilize
    Serial.println("Unit PoE-P4 IRremote example");
    // Initialize IR communication
    IrSender.begin(DISABLE_LED_FEEDBACK);  // Initialize IR sender without LED feedback
    IrSender.setSendPin(IR_SEND_PIN);      // Assign transmitter pin
    Serial.printf("IR Send Pin: %d\n", IR_SEND_PIN);
    delay(500); // Wait for hardware components to stabilize
    // Send infrared signal using NEC protocol
    Serial.printf("Send NEC: addr=0x%04x, cmd=0x%02x\n", address, command);
    IrSender.sendNEC(address, command, repeats);
    // Update transmission parameters for next cycle
    address += 0x0001;  // Increment device address
    command += 0x01;     // Increment command code
    repeats  = 0;        // Disable repeat frames (set >0 to test repeats)
    delay(2000);
Unit PoE-P4 transmits an NEC infrared frame every two seconds. The address and command values start at 0x0000 and 0x55, respectively, and increment on each transmission. You can verify reception using any remote that supports the NEC protocol.
Driver Library
