Unit ChainBus Arduino Tutorial
2. Notes
Pin compatibility
Since the pin configuration of each host is different, please refer to the Pin Compatibility Table in the product documentation before use, and modify the example program according to the actual pin connection.
3. Compile & Upload
  • 1. Enter download mode: Press and hold the reset button on CoreS3-SE (approximately 2 seconds) until the internal green LED lights up, then release it. The device is now in download mode, waiting for programming. The green LED turns off after the button is released, confirming that the device is in download mode.
Different devices require entering download mode before program uploading, which may vary for different main controllers. For details, refer to the device program download tutorial list at the bottom of the Arduino IDE Getting Started Guide page to see the specific operation method.
  • 2. Select the device port and click the compile and upload button in the upper left corner of Arduino IDE. Wait for the program to complete compilation and upload to the device.
4. Example
  • The main controller used in this tutorial is CoreS3-SE, powered by the Base M5GO Bottom3, using PORT.C. It works with Unit ChainBus and other modules to achieve the demo effects. This module communicates via UART. Modify the pin definitions in the program according to your actual circuit connections. After connection, the corresponding UART IOs are G17 (RX), G18 (TX).
If the host restarts without a power cycle, the GPIO work mode on Unit ChainBus will retain the last configured state. For example, if GPIO2 was set to input mode, after a non-power-off restart, GPIO2 will still remain in input mode even if its work mode is not configured again.
4.1 I2C Mode
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205
#include "M5Chain.h"
#include "M5Unified.h"
#define TXD_PIN GPIO_NUM_17  // Tx
#define RXD_PIN GPIO_NUM_18  // Rx
Chain M5Chain;
device_list_t *devices_list = NULL;
chain_status_t chain_status;
uint16_t device_nums     = 0;
uint8_t operation_status = 0;
work_status_t gpio1;
work_status_t gpio2;
void printWorkStatus(String gpio_num, work_status_t gpio_status);
bool sht3x_update(UnitChainBus& chain, uint8_t chainId, uint8_t sht3xAddr, float& cTemp, float& fTemp, float& humidity);
/* ---------- SHT3X STRUCT ---------- */
typedef struct {
    UnitChainBus* chain;
    uint8_t uart_id;
    uint8_t i2c_addr;
    float cTemp;
    float fTemp;
    float humidity;
    bool update()
        if (chain == nullptr) return false;
        return sht3x_update(*chain, uart_id, i2c_addr,
                                     cTemp, fTemp, humidity);
} SHT3X_t;
SHT3X_t sht3x;
    M5.Display.clear();
    M5.Display.setFont(&FreeMonoBold12pt7b);
    M5.Display.drawCenterString("Unit ChainBus Test", 160, 120);
    Serial.println("Unit ChainBus Test");
    // Check whether any Unit Chain device is connected
    if (M5Chain.isDeviceConnected()) {
        Serial.println("devices is connected");
        chain_status = M5Chain.getDeviceNum(&device_nums);
        if (chain_status == CHAIN_OK) {
            devices_list          = (device_list_t *)malloc(sizeof(device_list_t));
            devices_list->count   = device_nums;
            devices_list->devices = (device_info_t *)malloc(sizeof(device_info_t) * device_nums);
            // Get detailed device list
            if (M5Chain.getDeviceList(devices_list)) {
                Serial.println("devices list get success");
                Serial.println("devices list get failed");
            Serial.printf("error status:%d \r\n", chain_status);
            Serial.printf("devices num get failed.\r\n");
        Serial.println("devices is not connected.");
    if (devices_list->devices[0].device_type == UNIT_CHAIN_BUS_TYPE_CODE) {
        Serial.println("ID[1] is Unit ChainBus\n");
        chain_status = M5Chain.setChainBusI2cMode(devices_list->devices[0].id, CHAIN_I2C_HIGH_SPEED_400KHZ, &operation_status);// set i2c mode
        if (chain_status == CHAIN_OK && operation_status == 1) {
            Serial.printf("Unit ChainBus ID[%d] set i2c mode success \r\n", devices_list->devices[0].id);
            M5Chain.getChainBusWorkMode(devices_list->devices[0].id, &gpio1, &gpio2);// Read Unit ChainBus GPIO working status
            printWorkStatus("GPIO_1", (work_status_t)gpio1);
            printWorkStatus("GPIO_2", (work_status_t)gpio2);
            Serial.printf("Unit ChainBus ID[%d] set i2c mode fail, chain_status:%d  operation_status:%d \r\n", devices_list->devices[0].id, chain_status, operation_status);
        delay(500);
        // Bind SHT3X to this ChainBus
        sht3x.chain    = &M5Chain;
        sht3x.uart_id  = devices_list->devices[0].id;
        sht3x.i2c_addr = 0x44;  // SHT3X I2C address, can get from getChainBusI2cScanAddr
        Serial.printf("\nUnit ENV-III SHT3X bind to ChainBus ID[%d]\r\n", sht3x.uart_id);
        Serial.println("ID[1] is NOT Unit ChainBus\n");
        return;
    delay(5);
    if (sht3x.update()) {
        Serial.println("-----SHT3X-----");
        Serial.print("Temperature: ");
        Serial.print(sht3x.cTemp);
        Serial.println(" 'C");
        Serial.print("Humidity: ");
        Serial.print(sht3x.humidity);
        Serial.println("% rH");
        Serial.println("--------------\r\n");
        M5.Display.fillRect(0, 0, 320, 240, TFT_BLACK);
        M5.Display.setCursor(0, 20);
        M5.Display.println("-----SHT3X-----");
        M5.Display.print("Temperature: ");
        M5.Display.print(sht3x.cTemp);
        M5.Display.println(" 'C");
        M5.Display.print("Humidity: ");
        M5.Display.print(sht3x.humidity);
        M5.Display.println("% rH");
        M5.Display.println("---------------\r\n");
    Serial.print("  >>> " + gpio_num + ": ");
    switch (gpio_status) {
        case CHAIN_NOT_WORK_STATUS:
            Serial.println("Not configured working status");
            break;
        case CHAIN_OUTPUT_WORK_STATUS:
            Serial.println("Output status");
            break;
        case CHAIN_INPUT_WORK_STATUS:
            Serial.println("Input status");
            break;
        case CHAIN_NVIC_WORK_STATUS:
            Serial.println("External interrupt working status");
            break;
        case CHAIN_ADC_WORK_STATUS:
            Serial.println("ADC working status");
            break;
        case CHAIN_I2C_WORK_STATUS:
            Serial.println("I2C working status");
            break;
        default:
            Serial.println("Unrecognized work status");
            break;
// Perform one complete SHT3X measurement cycle via Unit ChainBus I2C
                         uint8_t chainId,
                         uint8_t sht3xAddr,
                         float& cTemp,
                         float& fTemp,
                         float& humidity)
    uint8_t opStatus = 0;
    chain_status_t status;
    // 1. Send measurement command (high repeatability, clock stretching disabled)
    uint8_t cmd[2] = {0x2C, 0x06};
    status = chain.chainBusI2cWrite(
        chainId,
        sht3xAddr,
        2,
        cmd,
        &opStatus,
        1000
    if (status != CHAIN_OK || opStatus != CHAIN_BUS_OPERATION_SUCCESS) {
        return false;
    // 2. Wait for the measurement to complete
    delay(100);
    // 3. Read 6 bytes of measurement data
    uint8_t data[6] = {0};
    status = chain.chainBusI2cRead(
        chainId,
        sht3xAddr,
        6,
        data,
        &opStatus,
        1000
        return false;
    // 4. Convert raw data to temperature and humidity
    cTemp = ((((data[0] * 256.0) + data[1]) * 175.0) / 65535.0) - 45.0;
    fTemp = (cTemp * 1.8) + 32.0;
    humidity = ((((data[3] * 256.0) + data[4]) * 100.0) / 65535.0);
    return true;
After power-on, the serial monitor will output information about the connected devices, and read temperature and humidity data from the SHT3X sensor on Unit ENV-III via the Unit ChainBus interface.
Example serial monitor output:
Unit ChainBus Test
Unit ChainBus ID[1] set i2c mode success
  >>> GPIO_1: I2C working status
  >>> GPIO_2: I2C working status
Unit ENV-III SHT3X bind to ChainBus ID[1]
-----SHT3X-----
Temperature: 27.19 'C
Humidity: 52.88% rH
4.2 Input Mode
Chain M5Chain;
    M5.Display.clear();
        chain_status = M5Chain.setChainBusInputMode(devices_list->devices[0].id, CHAIN_GPIO_PIN_1, CHAIN_GPIO_PULL_UP, &operation_status, 3000);// set GPIO1 input mode
            Serial.printf("Unit ChainBus ID[%d] set GPIO1 input mode success \r\n", devices_list->devices[0].id);
            Serial.printf("Unit ChainBus ID[%d] set GPIO1 input mode fail, chain_status:%d  operation_status:%d \r\n", devices_list->devices[0].id, chain_status, operation_status);
        delay(500);
        return;
    delay(5);
uint8_t last_button_status = true;
    uint8_t button_status;
    // Read GPIO1 input level from Unit ChainBus
    chain_status = M5Chain.getChainBusInputLevel(devices_list->devices[0].id, CHAIN_GPIO_PIN_1, &button_status, &operation_status);
        if (button_status != last_button_status) {
            Serial.printf("button status: %d \r\n", button_status);
            last_button_status = button_status;
        Serial.printf("get button status failed, chain_status:%d  operation_status:%d \r\n", chain_status,
                      operation_status);
    delay(20);
            break;
            break;
            break;
            break;
            break;
            break;
        default:
            break;
After power-on, the serial monitor will output information about the connected devices, and read the blue button state changes on Unit Dual Button via the Unit ChainBus interface.
Unit ChainBus Test
Unit ChainBus ID[1] set GPIO1 input mode success
  >>> GPIO_1: Input status
  >>> GPIO_2: Not configured working status
button status: 0
button status: 1
4.3 Output Mode
The program below controls both GPIO1 and GPIO2 on Unit ChainBus. GPIO1 toggles between high and low every 500 ms, while GPIO2 is held low. You can connect an LED for observation.
Chain M5Chain;
    M5.Display.clear();
        chain_status = M5Chain.setChainBusOutputMode(devices_list->devices[0].id, CHAIN_GPIO_PIN_1, CHAIN_GPIO_OUTPUT_PUSHPULL, CHAIN_GPIO_PULL_DOWN, &operation_status, 3000);// set output mode
        chain_status = (chain_status_t)(chain_status &
                    M5Chain.setChainBusOutputMode(devices_list->devices[0].id, CHAIN_GPIO_PIN_2, CHAIN_GPIO_OUTPUT_PUSHPULL, CHAIN_GPIO_PULL_DOWN, &operation_status, 3000));// set output mode
            Serial.printf("Unit ChainBus ID[%d] set output mode success \r\n", devices_list->devices[0].id);
            M5Chain.setChainBusOutputLevel(devices_list->devices[0].id, CHAIN_GPIO_PIN_2, CHAIN_GPIO_RESET, &operation_status);// set GPIO2 output level - low
            Serial.printf("Unit ChainBus ID[%d] set output mode fail, chain_status:%d  operation_status:%d \r\n", devices_list->devices[0].id, chain_status, operation_status);
        delay(500);
        return;
    delay(5);
bool flag = false;
    // change GPIO1 output level
    flag = !flag;
    chain_status = M5Chain.setChainBusOutputLevel(devices_list->devices[0].id, CHAIN_GPIO_PIN_1, flag ? CHAIN_GPIO_SET : CHAIN_GPIO_RESET, &operation_status);
        if (flag) {
            Serial.println("set gpio1 high level");
            Serial.println("set gpio1 low level");
        Serial.printf("set gpio1 level failed, chain_status:%d  operation_status:%d \r\n", chain_status, operation_status);
    delay(500);
            break;
            break;
            break;
            break;
            break;
            break;
        default:
            break;
After power-on, the serial monitor will output information about the connected devices, and control the LED connected to Unit ChainBus to blink.
Unit ChainBus Test
Unit ChainBus ID[1] set output mode success
  >>> GPIO_1: Output status
  >>> GPIO_2: Output status
set gpio1 low level
set gpio1 low level
4.4 Interrupt Mode
Chain M5Chain;
    M5.Display.clear();
    M5.Display.drawCenterString("Unit ChainBus Nvic Test", 160, 120);
    Serial.println("Unit ChainBus Nvic Test");
        // Configure GPIO1 as NVIC (external interrupt) mode, rising edge trigger
        chain_status = M5Chain.setChainBusNvicMode(devices_list->devices[0].id, CHAIN_GPIO_PIN_1, CHAIN_GPIO_PULL_UP,
                                                    CHAIN_GPIO_MODE_IT_RISING, &operation_status);
            Serial.printf("ChainBus ID[%d] set gpio1 nvic mode RISING success \r\n", devices_list->devices[0].id);
            Serial.printf("ChainBus ID[%d] set gpio1 nvic mode RISING fail, chain_status:%d  operation_status:%d \r\n",
        // Configure GPIO2 as NVIC (external interrupt) mode, rising and falling edge trigger
        chain_status = M5Chain.setChainBusNvicMode(devices_list->devices[0].id, CHAIN_GPIO_PIN_2, CHAIN_GPIO_PULL_UP,
                                                    CHAIN_GPIO_MODE_IT_RISING_FALLING, &operation_status);
            Serial.printf("ChainBus ID[%d] set gpio2 nvic mode RISING_FALLING success \r\n", devices_list->devices[0].id);
            Serial.printf("ChainBus ID[%d] set gpio2 mode RISING_FALLING fail, chain_status:%d  operation_status:%d \r\n",
        delay(500);
        return;
    delay(5);
    if (devices_list) {
            // Check whether GPIO1 or GPIO2 is configured as NVIC mode
            if (gpio1 == CHAIN_NVIC_WORK_STATUS || gpio2 == CHAIN_NVIC_WORK_STATUS) {
                uint16_t nvic_status = 0;
                while (M5Chain.getChainBusNvicTriggerStatus(devices_list->devices[0].id, &nvic_status)) {
                    Serial.println("**********************************");
                    Serial.printf("ChainBus ID[%d] nvic status: 0x%04x \r\n", devices_list->devices[0].id, nvic_status);
            Serial.printf("ChainBus ID[%d] get work mode fail, chain_status:%d  operation_status:%d \r\n",
    delay(40);
            break;
            break;
            break;
            break;
            break;
            break;
        default:
            break;
After power-on, the serial monitor will output information about the connected devices and read the interrupt trigger status of the Unit Dual Button connected to Unit ChainBus. Pressing the blue button triggers a rising-edge interrupt, and the serial port returns the corresponding message once; pressing the red button triggers both rising- and falling-edge interrupts, and the serial port returns the corresponding message twice. In the returned hexadecimal value, the low byte indicates the pin level state before the interrupt was triggered, and the high byte indicates the GPIO number that triggered the interrupt.
ChainBus ID[1] set gpio1 nvic mode RISING success
ChainBus ID[1] set gpio2 nvic mode RISING_FALLING success
  >>> GPIO_1: External interrupt working status
  >>> GPIO_2: External interrupt working status
ChainBus ID[1] nvic status: 0x0100
ChainBus ID[1] nvic status: 0x0201
ChainBus ID[1] nvic status: 0x0200
4.5 ADC Mode
Chain M5Chain;
    M5.Display.clear();
        // Configure GPIO1 as ADC input mode
        chain_status = M5Chain.setChainBusAdcMode(devices_list->devices[0].id, CHAIN_GPIO_PIN_1, &operation_status, 3000);
            Serial.printf("ChainBus ID[%d] set GPIO1 adc mode success \r\n", devices_list->devices[0].id);
            Serial.printf("ChainBus ID[%d] set GPIO1 adc mode fail, chain_status:%d  operation_status:%d \r\n",
        delay(500);
        return;
    delay(5);
uint16_t last_adc_value = 0;
    uint16_t adc_value;
    chain_status = M5Chain.getChainBusAdcValue(devices_list->devices[0].id, CHAIN_GPIO_PIN_1, &adc_value, &operation_status);
        if (abs(adc_value - last_adc_value) > 4) {// Print ADC value only when the change exceeds the threshold
            Serial.printf("\nADC value: %d \r\n", adc_value);
            last_adc_value = adc_value;
        Serial.printf("get ADC value failed, chain_status:%d  operation_status:%d \r\n", chain_status, operation_status);
    delay(100);
            break;
            break;
            break;
            break;
            break;
            break;
        default:
            break;
After power-on, the serial monitor will output information about the connected devices, and read the ADC value from Unit Angle via the Unit ChainBus interface.
Unit ChainBus Test
ChainBus ID[1] set GPIO1 adc mode success
  >>> GPIO_1: ADC working status
ADC value: 4095
