Unit PoE-P4 Arduino Program Compilation & Upload
  • 3.Library Installation: Refer to Library Management Installation Guide to complete the installation of M5Unified and M5GFX driver libraries, and follow the prompts to install all the required libraries.
2. Download Mode
Connect the device to your computer via a USB Type-C cable. Press and hold the side reset button for about 2 seconds until the green LED lights up. Release the button and the device will enter download mode, ready for programming.
3. Program Compilation & Upload
Open the example program "ETH_TLK110" in the Ethernet library, click the upload button, and the program will be automatically compiled and uploaded.
After the upload is successful, open the serial monitor and set the baud rate to 115200. You should see output information indicating a successful network connection.
Serial output example:
  • Network connection successful
ETH Started
ETH Connected
ETH Got IP
*eth0: <UP,100M,FULL_DUPLEX,AUTO,ADDR:0x1> (DHCPC,GARP,IP_MOD)
      ether 30:ED:A0:EA:92:D2
      inet 192.168.20.121 netmask 255.255.255.0 broadcast 192.168.20.255
      gateway 192.168.20.1 dns 223.5.5.5
connecting to baidu.com
HTTP/1.1 301 Moved Permanently
Date: Sat, 28 Feb 2026 04:29:55 GMT
Content-Length: 57
Content-Type: text/html; charset=utf-8
<a href="https://www.baidu.com/">Moved Permanently</a>.
closing connection
  • Network connection failed
ETH Disconnected
ETH Connected
ETH Got IP
connecting to google.com
connection failed
