Environment setup: Refer to Arduino IDE Quick Start to complete IDE installation, and install the corresponding board package for the development board in use along with the required driver libraries.
Required libraries:
Required hardware products:
This tutorial demonstrates how to use the AtomS3R together with the Voice Pyramid. Pin pairing can be referenced in the compatibility diagram below.
Voice Pyramid is a professional development base designed for smart voice applications, specifically built for the M5Stack Atom series controllers. By vertically inserting an Atom controller into the reserved header pins, developers can quickly build voice-enabled devices with powerful audio interaction capabilities. The ATOM module (based on ESP32 or ESP32-S3) serves as the main controller, handling audio processing, wireless communication (Wi-Fi/Bluetooth), and IoT connectivity, making it suitable for various voice interaction scenarios such as voice assistants, smart control hubs, and IoT voice terminals.
The device features a high-quality audio system with an ES8311 audio codec and an ES7210 dual-microphone front-end with MEMS microphones for clear voice capture and noise suppression. A built-in 2W speaker powered by the AW87559 Class-D amplifier provides powerful audio output. For interaction, an STM32G030F6P6 microcontroller manages capacitive touch inputs and RGB LEDs, offering responsive touch control and dynamic visual feedback. The system also integrates a Si5351 programmable clock generator to ensure stable audio performance for voice applications.
Touch: Four capacitive touch pads enable intuitive user interaction and quick control of device functions.
Microphone: Dual MEMS microphones support clear voice capture and are suitable for voice recognition and voice command applications.
RGB LED: Integrated programmable RGB LEDs provide visual feedback, status indication, and dynamic lighting effects.
Speaker: A built-in 2W speaker delivers clear audio playback for voice responses, notifications, and multimedia output.
Press and hold the button on the right side of the AtomS3R, then connect the USB cable to the device.
The following examples demonstrate the core hardware features and basic usage of the Voice Pyramid. These examples cover RGB LED control, audio recording and playback, touch interaction, and microphone audio capture, helping users quickly understand how to interact with the device and access its main peripherals through simple Arduino programs. By uploading these example programs, developers can learn how to control the RGB LEDs, detect touch input, record and play audio through the microphone and speaker, and monitor device status through the Serial Monitor.
#include "M5Unified.h"
#include <M5EchoPyramid.h>
M5EchoPyramid ep;
int brightness = 0;
int step = 5;
bool rising = true;
int leds[4] = {0, 3, 7, 10};
Wire1.end();
ep.begin(&Wire1, 38, 39, 6, 8, 5, 7, 44100);
ep.ctrl().setBrightness(1, 100);
ep.ctrl().setBrightness(2, 100);
Serial.println("LED demo start");
if (rising)
brightness += step;
if (brightness >= 255)
brightness = 255;
rising = false;
else
brightness -= step;
if (brightness <= 10)
brightness = 10;
rising = true;
for (int i = 0; i < 4; i++)
ep.ctrl().setRGB(1, leds[i], brightness, 0, 255 - brightness);
ep.ctrl().setRGB(2, leds[i], brightness, 0, 255 - brightness);
delay(40);
}Copy the program above into Arduino IDE, click the Upload button, and wait until the compilation and upload process are completed. After the program starts running on the device, four LEDs on the Voice Pyramid (positions 0, 3, 7, and 10) on both LED rings will begin displaying a smooth breathing color effect. The LED brightness will gradually increase and decrease, while the color transitions between red and blue, creating a purple gradient during the transition. This animation loops continuously, demonstrating how to control the RGB LEDs on the Voice Pyramid.
#define SAMPLE_RATE 44100
#define RECORD_SECONDS 5
#define FRAME_SIZE 256
#define TOTAL_SAMPLES (SAMPLE_RATE * RECORD_SECONDS)
M5EchoPyramid ep;
int16_t *recordBuffer = nullptr;
bool recordingBusy = false;
void recordAndPlay5s()
if (recordingBusy) return;
recordingBusy = true;
Serial.println("Start 5s Recording...");
int16_t mic[FRAME_SIZE];
int16_t ref[FRAME_SIZE];
int written = 0;
while (written < TOTAL_SAMPLES) {
ep.read(mic, ref, FRAME_SIZE);
memcpy(recordBuffer + written, mic, FRAME_SIZE * sizeof(int16_t));
written += FRAME_SIZE;
Serial.println("Recording Done.");
delay(200);
Serial.println("Start Playback...");
int played = 0;
while (played < TOTAL_SAMPLES) {
ep.write(recordBuffer + played, FRAME_SIZE);
played += FRAME_SIZE;
Serial.println("Playback Done.");
delay(2000);
Wire1.end();
ep.begin(&Wire1, 38, 39, 6, 8, 5, 7, SAMPLE_RATE);
ep.codec().setVolume(50);
ep.codec().mute(false);
recordBuffer = (int16_t *)malloc(TOTAL_SAMPLES * sizeof(int16_t));
if (!recordBuffer) {
Serial.println("Memory allocation failed!");
while (1) {
Serial.println("System Ready. Press touch1 to record & play 5s audio.");
if (ep.ctrl().isPressed(1)) {
recordAndPlay5s();
while (ep.ctrl().isPressed(1)) {
delay(10);
delay(10);
}Copy the program above into Arduino IDE, click the Upload button, and wait until the compilation and upload process are completed. After the device starts running, press Touch Button 1 on the Voice Pyramid to begin recording. The device will capture 5 seconds of audio from the built-in microphone and store the raw PCM data in memory. Once the recording is finished, the device will automatically play back the recorded audio through the speaker. Messages such as “Start 5s Recording…”, “Recording Done.”, “Start Playback…”, and “Playback Done.” will be displayed in the Serial Monitor, demonstrating how to record and immediately play back audio using the Voice Pyramid.
#define INITIAL_BRIGHTNESS 50
#define INITIAL_VOLUME 50
#define STEP 5
M5EchoPyramid ep;
int brightnessLevel = INITIAL_BRIGHTNESS;
int volumeLevel = INITIAL_VOLUME;
bool brightnessGestureActive = false;
bool volumeGestureActive = false;
void applyBrightness()
ep.ctrl().setBrightness(1, brightnessLevel);
ep.ctrl().setBrightness(2, brightnessLevel);
void fillLedsColor(uint8_t r, uint8_t g, uint8_t b)
for (int i = 0; i < 14; ++i) {
ep.ctrl().setRGB(1, i, r, g, b);
ep.ctrl().setRGB(2, i, r, g, b);
void applyVolume()
ep.codec().setVolume(volumeLevel);
delay(2000);
Wire1.end();
fillLedsColor(255, 255, 255);
applyBrightness();
applyVolume();
bool t1 = ep.ctrl().isPressed(1);
bool t2 = ep.ctrl().isPressed(2);
bool t3 = ep.ctrl().isPressed(3);
bool t4 = ep.ctrl().isPressed(4);
if (!brightnessGestureActive) {
if (t1 && !t2) {
brightnessGestureActive = true;
brightnessLevel += STEP;
if (brightnessLevel > 100) brightnessLevel = 100;
applyBrightness();
Serial.printf("Brightness: %d%%\n", brightnessLevel);
} else if (t2 && !t1) {
brightnessLevel -= STEP;
if (brightnessLevel < 0) brightnessLevel = 0;
applyBrightness();
if (!t1 && !t2) {
if (!volumeGestureActive) {
if (t4 && !t3) {
volumeGestureActive = true;
volumeLevel += STEP;
if (volumeLevel > 100) volumeLevel = 100;
applyVolume();
Serial.printf("Volume: %d%%\n", volumeLevel);
} else if (t3 && !t4) {
volumeLevel -= STEP;
if (volumeLevel < 0) volumeLevel = 0;
applyVolume();
if (!t3 && !t4) {
delay(10);
}Copy the program above into Arduino IDE, click the Upload button, and wait until the compilation and upload process are complete. After the firmware is running on the Voice Pyramid, the four touch pads can be used to control LED brightness and speaker volume.
Touch1 ~ Touch2:
These two touch pads control the LED brightness of the device.
Touch3 ~ Touch4:
These two touch pads control the speaker volume.
M5EchoPyramid ep;
void record5s()
int written = 0;
const int channels = 1;
const int bitsPerSample = 16;
const int totalSamples = TOTAL_SAMPLES;
const size_t totalBytes = totalSamples * sizeof(int16_t);
const float durationSeconds = (float)totalSamples / SAMPLE_RATE;
const int totalFrames = totalSamples / FRAME_SIZE;
Serial.println("=== Record Info ===");
Serial.printf("Sample rate : %d Hz\n", SAMPLE_RATE);
Serial.printf("Channels : %d (mono)\n", channels);
Serial.printf("Bits per sample: %d bit\n", bitsPerSample);
Serial.printf("Total samples : %d\n", totalSamples);
Serial.printf("Total frames : %d (frame size = %d)\n", totalFrames, FRAME_SIZE);
Serial.printf("Total bytes : %u (%.2f KB)\n", (unsigned int)totalBytes, totalBytes / 1024.0f);
Serial.printf("Duration : %.3f s\n", durationSeconds);
Serial.println("====================");
delay(2000);
Wire1.end();
while (1) {
Serial.println("System Ready. Press touch1 to record 5s audio.");
record5s();
delay(10);
delay(10);
}Copy the program above into Arduino IDE, click the Upload button, and wait until the compilation and upload process are completed. After the device starts running, press Touch Button 1 on the Voice Pyramid to start recording audio. The device will record 5 seconds of sound from the built-in microphone, store the raw PCM data in memory, and print the recording information to the Serial Monitor, including the sample rate (44.1 kHz), channel configuration (mono), bit depth (16-bit), total samples, frame count, data size, and recording duration. This example demonstrates how to capture microphone audio data and analyze the recording parameters using the Voice Pyramid audio interface.
