Stamp C6LoRa EXT IO
Stamp C6LoRa integrates the PI4IOE5V6408 IO expansion chip internally. In addition to controlling the LoRa module's transceiver circuit and signal amplifier enable, it also exposes the EXT_P0 ~ P4 interfaces to provide additional IO resources.
Example Code
Compilation Requirements
  • M5Stack Board Manager version >= 3.2.6
  • Board Option = M5StampC6LoRa
  • M5Unified library version >= 0.2.13
  • M5GFX library version >= 0.2.19
Output
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
#include <Arduino.h>
#include "utility/PI4IOE5V6408_Class.hpp"
m5::I2C_Class i2c_bus_0;
m5::PI4IOE5V6408_Class ioe(0x43, 400000, &i2c_bus_0);
    delay(300);
    Serial.println("PI4IOE5V6408 Output Example");
    if (!i2c_bus_0.begin(I2C_NUM_0, 10, 8)) {
        Serial.println("I2C init failed");
        while (true) delay(1000);
    if (!ioe.begin()) {
        Serial.println("IOE init failed");
    for (int i = 0; i < 5; i++) {
        ioe.setDirection(i, true);      // output
        ioe.setHighImpedance(i, false); // disable high-impedance so pin can actually drive
        ioe.digitalWrite(i, false);     // default low
    static bool state = false;
    state = !state;
        ioe.digitalWrite(i, state);
        Serial.printf("[EXT_P%d] %d  ", i, (int)state);
    Serial.println();
Input
    delay(300);
    Serial.println("PI4IOE5V6408 Input Example");
    if (!ioe.begin()) {
        ioe.setDirection(i, false);   // input
        ioe.enablePull(i, true);      // enable internal pull resistor
        ioe.setPullMode(i, true);     // pull-up (true=up, false=down)
        Serial.printf("[EXT_P%d] %d  ", i, (int)ioe.digitalRead(i));
    Serial.println();
