Atomic Audio-3.5 Base Arduino Tutorial
2. Microphone selection switch
The microphone selection switch on the Atomic Audio-3.5 Base is located as shown below. It selects the microphone input channel to suit different use cases.
The switch has two positions:
  • ON: Keep the onboard microphone powered; when external speakers are connected, continue using the built-in microphone.
  • OFF: When a device is connected to the 3.5mm jack, automatically switch to the external microphone — suitable for headsets or external mic use.
3. Example
Refer to the RecordPlay example in the M5Atomic-EchoBase repository. Adjust IO definitions in the sketch according to your wiring. This tutorial targets AtomS3R; the IO mapping used here matches AtomS3.
Note: The Atomic Audio-3.5 Base microphone supports sample rates between 16 kHz and 64 kHz. Configure a valid sample rate during initialization.
3.1 Initialization
1 2 3 4 5 6
// Initialize the EchoBase with ATOMS3 pinmap.
echobase.init(44100 /*Sample Rate*/, 38 /*I2C SDA*/, 39 /*I2C SCL*/, 7 /*I2S DIN*/, 6 /*I2S WS*/,
                       5 /*I2S DOUT*/, 8 /*I2S BCK*/, Wire);
echobase.setSpeakerVolume(50);             // Set speaker volume to 50%.
echobase.setMicGain(ES8311_MIC_GAIN_6DB);  // Set microphone gain to 6dB.
3.2 Recording and playback
1 2 3 4 5 6 7 8 9 10 11
// Recording
echobase.setMute(true);
delay(10);
echobase.record(buffer, RECORD_SIZE);  // Record audio into buffer.
delay(100);
// Playing
echobase.setMute(false);
delay(10);
echobase.play(buffer, RECORD_SIZE);  // Play audio from buffer.
delay(100);
3.3 Complete Program
The following example uses M5Unified and M5GFX to provide a basic display and button control: press the button to record, then automatically play back the recording when finished.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
#include "M5Unified.h"
#include "M5EchoBase.h"
#if defined(CONFIG_IDF_TARGET_ESP32S3)
#define RECORD_SIZE (1024 * 200)
#elif defined(CONFIG_IDF_TARGET_ESP32)
#define RECORD_SIZE (1024 * 96)
#endif
// Create an instance of the M5EchoBase class
#if (ESP_IDF_VERSION >= ESP_IDF_VERSION_VAL(5, 0, 0))
M5EchoBase echobase;
#else
M5EchoBase echobase(I2S_NUM_0);
#endif
static uint8_t *buffer = nullptr;  // Pointer to hold the audio buffer.
    if (!echobase.init(44100 /*Sample Rate*/, 38 /*I2C SDA*/, 39 /*I2C SCL*/, 7 /*I2S DIN*/, 6 /*I2S WS*/,
                       5 /*I2S DOUT*/, 8 /*I2S BCK*/, Wire) != 0) {
        Serial.println("Failed to initialize EchoBase!");
        while (true) {
    // Initialize the EchoBase with ATOM pinmap.
    if (!echobase.init(44100 /*Sample Rate*/, 25 /*I2C SDA*/, 21 /*I2C SCL*/, 23 /*I2S DIN*/, 19 /*I2S WS*/, 22 /*I2S
    DOUT*/, 33 /*I2S BCK*/, Wire) != 0) {
        while (true) {
#endif
    buffer = (uint8_t *)malloc(RECORD_SIZE);  // Allocate memory for the record buffer.
    // Check if memory allocation was successful.
    if (buffer == nullptr) {
        // If memory allocation fails, enter an infinite loop.
        while (true) {
            Serial.println("Failed to allocate memory :(");
    Serial.println("Device ready, start recording and playing!");
    M5.Display.println("Click to \nRecord and Play");
    if (M5.BtnA.wasClicked()) {
        M5.Display.fillScreen(BLACK);
        M5.Display.setCursor(0, 0);
        M5.Display.println("Recording");
        Serial.println("Start recording...");
        // Recording
        delay(10);
        delay(100);
        M5.Display.println("Playing");
        Serial.println("Start playing...");
        // Playing
        delay(10);
        delay(100);
        M5.Display.println("Done");
        Serial.println("Done");
4. Compile & Upload
  • 1. Download mode: Entering the boot/download mode varies by controller. See the device-specific download instructions at the bottom of the Arduino IDE Getting Started guide.
  • For AtomS3R: press and hold the reset button for about 2 seconds until the internal green LED lights, then release — the device enters download mode and is ready for flashing.
  • 2. Select the device port and click the Arduino IDE upload button (top-left). Wait for compilation and upload to complete.
5. Recording & Playback
