Module13.2 2Relay Arduino Tutorial
2. Notes
High-voltage contacts
The relay contacts of Module13.2 2Relay support up to AC 250V@5A. Disconnect the power before wiring, disconnecting wires, or replacing a load. Do not operate exposed contacts while they are energized. During actual use, confirm the safe operating range according to the load type, wiring method, and relay specifications.
Pin compatibility
Since the pin configuration differs between hosts, refer to the Pin Compatibility Table in the product documentation before use, and modify the example program according to the actual connection.
3. Example Programs
3.1 Relay Control
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149
#include <M5GFX.h>
#include <Wire.h>
#include "MODULE_2RELAY.h"
M5Canvas canvas(&M5.Display);
MODULE_2RELAY RELAY;
constexpr uint8_t RELAY_I2C_ADDRESS = MODULE_2RELAY_ADDR;
constexpr uint8_t RELAY_SDA = 12;
constexpr uint8_t RELAY_SCL = 11;
uint8_t stepChannel = 0;
constexpr int16_t TOUCH_BUTTON_Y = 176;
constexpr int16_t TOUCH_BUTTON_HEIGHT = 58;
constexpr int16_t TOUCH_BUTTON_WIDTH = 100;
constexpr int16_t TOUCH_BUTTON_GAP = 6;
int16_t getButtonX(uint8_t index)
    return TOUCH_BUTTON_GAP + index * (TOUCH_BUTTON_WIDTH + TOUCH_BUTTON_GAP);
int8_t getTouchedButton(int16_t x, int16_t y)
    if (y < TOUCH_BUTTON_Y || y >= TOUCH_BUTTON_Y + TOUCH_BUTTON_HEIGHT) {
        return -1;
    for (uint8_t index = 0; index < 3; ++index) {
        const int16_t buttonX = getButtonX(index);
        if (x >= buttonX && x < buttonX + TOUCH_BUTTON_WIDTH) {
            return index;
    return -1;
void drawTouchButton(uint8_t index, const char *label)
    const int16_t x = getButtonX(index);
    canvas.fillRoundRect(x, TOUCH_BUTTON_Y, TOUCH_BUTTON_WIDTH,
                         TOUCH_BUTTON_HEIGHT, 5, TFT_DARKGREY);
    canvas.drawRoundRect(x, TOUCH_BUTTON_Y, TOUCH_BUTTON_WIDTH,
                         TOUCH_BUTTON_HEIGHT, 5, TFT_ORANGE);
    canvas.drawString(label, x + TOUCH_BUTTON_WIDTH / 2,
                      TOUCH_BUTTON_Y + TOUCH_BUTTON_HEIGHT / 2);
void drawStatus(const char *action)
    canvas.fillSprite(TFT_BLACK);
    canvas.setTextDatum(MC_DATUM);
    canvas.setTextColor(TFT_WHITE);
    canvas.drawString("Module13.2 2Relay", 160, 12);
    canvas.drawString(action, 160, 32);
    for (uint8_t channel = 0; channel < 2; ++channel) {
        const int16_t y = 50 + 42 * channel;
        const bool state = RELAY.getRelayState(channel);
        if (state) {
            canvas.fillRect(12, y, 136, 32, TFT_GREEN);
            canvas.drawRect(12, y, 136, 32, TFT_LIGHTGREY);
        canvas.drawString("CH" + String(channel + 1) +
                              (state ? ": ON" : ": OFF"),
                          80, y + 16);
    canvas.drawString("FW: " + String(RELAY.getVersion()),
                      160, 138);
    drawTouchButton(0, "REVERSE");
    drawTouchButton(1, "STEP");
    drawTouchButton(2, "ALL");
    canvas.pushSprite(0, 0);
void drawInitError()
    canvas.setTextColor(TFT_RED);
    canvas.drawString("Module13.2 2Relay ERROR", 160, 108);
    canvas.drawString("Check address / wiring", 160, 136);
    canvas.setColorDepth(8);
    canvas.setFont(&fonts::FreeMonoBold9pt7b);
    canvas.setTextSize(1);
    // while(!RELAY.begin(&Wire1, RELAY_SDA, RELAY_SCL, RELAY_I2C_ADDRESS)){
    while(!RELAY.begin(&M5.In_I2C, RELAY_I2C_ADDRESS)){
        Serial.println("Module13.2 2Relay INIT ERROR");
        drawInitError();
    Serial.println("Module13.2 2Relay INIT SUCCESS");
    drawStatus("Ready");
    const auto touch = M5.Touch.getDetail();
    if (touch.wasClicked()) {
        switch (getTouchedButton(touch.x, touch.y)) {
        case 0:
            drawStatus(RELAY.reverseRelay() ? "Reverse" : "Reverse Error");
            break;
        case 1: {
            const bool currentState = RELAY.getRelayState(stepChannel);
            if (RELAY.setRelay(stepChannel, !currentState)) {
                stepChannel = (stepChannel + 1) % 2;
                drawStatus("Step");
                drawStatus("Step Error");
            break;
        case 2: {
            const bool channel0 = RELAY.getRelayState(0);
            const bool channel1 = RELAY.getRelayState(1);
            const bool allOn = channel0 && channel1;
            const bool success = RELAY.setAllRelay(!allOn);
            drawStatus(success ? (allOn ? "All OFF" : "All ON")
                               : "All Error");
            break;
        default:
            break;
    delay(20);
3.2 Configure the I2C Address
This example uses the CoreS3 touchscreen and setDeviceAddr() to switch the Module13.2 2Relay I2C address between 0x26 and 0x66. At startup, the program checks 0x26 and 0x66 in sequence: when 0x26 is detected, the button target address is 0x66; when 0x66 is detected, the button target address is 0x26. If neither address is detected, an error message is shown on the screen. The code supports both Wire1 and M5.In_I2C initialization methods. As in Section 3.1, select one by commenting out or uncommenting the corresponding begin() call. Tap the SET ADDRESS area on the screen to switch the address.
#include <M5GFX.h>
#include <Wire.h>
constexpr uint8_t RELAY_ADDRESS_26 = 0x26;
constexpr uint8_t RELAY_ADDRESS_66 = 0x66;
constexpr int16_t ADDRESS_BUTTON_X = 60;
constexpr int16_t ADDRESS_BUTTON_Y = 110;
constexpr int16_t ADDRESS_BUTTON_WIDTH = 200;
constexpr int16_t ADDRESS_BUTTON_HEIGHT = 60;
bool moduleReady = false;
uint8_t currentRelayAddress = 0;
uint8_t newRelayAddress = 0;
void drawAddressScreen(const char *result = nullptr)
    M5.Display.setTextSize(1);
    M5.Display.setTextDatum(MC_DATUM);
    M5.Display.setTextColor(TFT_WHITE);
    M5.Display.drawString("Module13.2 2Relay", 160, 32);
    const String currentAddress = moduleReady ? String(currentRelayAddress, HEX)
                                              : String("--");
    const String newAddress = moduleReady ? String(newRelayAddress, HEX)
                                          : String("--");
    M5.Display.drawString("Current: 0x" + currentAddress +
                              " -> New: 0x" + newAddress,
                          160, 75);
    M5.Display.drawRoundRect(ADDRESS_BUTTON_X, ADDRESS_BUTTON_Y,
                             ADDRESS_BUTTON_WIDTH, ADDRESS_BUTTON_HEIGHT,
                             6, TFT_ORANGE);
    M5.Display.drawString("SET ADDRESS", 160, 140);
    if (result != nullptr) {
        M5.Display.drawString(result, 160, 205);
    // moduleReady = RELAY.begin(&Wire1, RELAY_SDA, RELAY_SCL, RELAY_ADDRESS_26);
    moduleReady = RELAY.begin(&M5.In_I2C, RELAY_ADDRESS_26);
    if (moduleReady) {
        currentRelayAddress = RELAY_ADDRESS_26;
        newRelayAddress = RELAY_ADDRESS_66;
        // moduleReady = RELAY.begin(&Wire1, RELAY_SDA, RELAY_SCL, RELAY_ADDRESS_66);
        moduleReady = RELAY.begin(&M5.In_I2C, RELAY_ADDRESS_66);
        if (moduleReady) {
            currentRelayAddress = RELAY_ADDRESS_66;
            newRelayAddress = RELAY_ADDRESS_26;
    if (moduleReady) {
        Serial.printf("Module13.2 2Relay found at 0x%02X\n",
                      currentRelayAddress);
        drawAddressScreen();
        drawAddressScreen("Module13.2 2Relay ERROR");
    if (touch.wasClicked() && touch.x >= ADDRESS_BUTTON_X &&
        touch.x < ADDRESS_BUTTON_X + ADDRESS_BUTTON_WIDTH &&
        touch.y >= ADDRESS_BUTTON_Y &&
        touch.y < ADDRESS_BUTTON_Y + ADDRESS_BUTTON_HEIGHT) {
        if (!moduleReady) {
            drawAddressScreen("Module not found");
        } else if (RELAY.setDeviceAddr(newRelayAddress)) {
            currentRelayAddress = newRelayAddress;
            newRelayAddress = (currentRelayAddress == RELAY_ADDRESS_26)
                                  ? RELAY_ADDRESS_66
                                  : RELAY_ADDRESS_26;
            Serial.printf("I2C address updated to 0x%02X\n",
            drawAddressScreen("Success!");
            Serial.println("I2C address update failed");
            drawAddressScreen("Failed!");
    delay(20);
4. Compile and Upload
    1. Enter download mode: Press and hold the CoreS3 reset button (for approximately 2 seconds) until the internal green LED lights up, then release it. After it is released, the green LED turns off, indicating that the device has entered download mode and is ready for flashing.
Different devices may require different procedures to enter download mode before uploading a program. For details, refer to the device program download tutorial list at the bottom of the Arduino IDE Getting Started Guide.
    1. Select the device port, click the compile and upload button in the upper-left corner of Arduino IDE, and wait for compilation and uploading to finish.
5. Relay Control
  • After uploading is complete, restart the CoreS3 to run the program. Tap REVERSE to reverse the states of both relays, STEP to switch the states of the two relays in sequence, or ALL to turn both relays on or off simultaneously.
