+5VOUT is the output terminal of Stamp Timer Power. Do not directly power it from an external supply by reverse-feeding it.
Stamp Timer Power must be supplied with a stable external 5V power source through 5VIN to operate normally and provide +5VOUT. +5VOUT can supply power to the host through the controller's PORT.A.
HOLD is the 5V output hold-control terminal of Stamp Timer Power. It uses 3.3V logic levels: a high level keeps the +5VOUT output enabled, while a low level disables the +5VOUT output.
+5VOUT, set cfg.output_power = false in the program to prevent the controller from reverse-driving the 5V output of PORT.A.#include <M5Unified.h>
static constexpr bool SET_RTC_ON_BOOT = true;
static constexpr uint32_t TIMER_SECONDS = 5;
static constexpr uint32_t DISPLAY_INTERVAL_MS = 1000;
static bool startTimer()
const uint32_t actualMs = M5.Rtc.setTimerIRQ(TIMER_SECONDS * 1000UL);
if (actualMs == 0) {
return false;
Serial.printf("RTC timer: %lu seconds\n",
static_cast<unsigned long>(actualMs / 1000UL));
return true;
static void stopWithError(const char* message)
Serial.println(message);
M5.Display.println(message);
while (true) {
auto cfg = M5.config();
cfg.output_power = false;
cfg.internal_rtc = false;
cfg.external_rtc = false;
M5.begin(cfg);
M5.Display.setCursor(0, 0);
M5.Display.println("Stamp Timer Power");
if (!M5.Rtc.begin(&M5.Ex_I2C)) {
stopWithError("RTC init failed");
if (SET_RTC_ON_BOOT) {
const m5::rtc_datetime_t dateTime{
m5::rtc_date_t(2026, 9, 2, 3),
m5::rtc_time_t(12, 0, 0),
M5.Rtc.setDateTime(dateTime);
M5.Rtc.setSystemTimeFromRtc();
if (M5.Rtc.getVoltLow()) {
Serial.println("RTC voltage low flag: SET");
Serial.println("RTC voltage low flag: CLEAR");
M5.Rtc.disableIRQ();
if (!startTimer()) {
stopWithError("RTC timer setup failed");
static bool timerFiredSinceLastDisplay = false;
const bool irq = M5.Rtc.getIRQstatus();
if (irq) {
Serial.println("RTC timer fired");
timerFiredSinceLastDisplay = true;
M5.Rtc.clearIRQ();
stopWithError("RTC timer restart failed");
static uint32_t lastDisplayMs = 0;
if (millis() - lastDisplayMs >= DISPLAY_INTERVAL_MS) {
lastDisplayMs = millis();
const bool displayIrq = timerFiredSinceLastDisplay;
m5::rtc_datetime_t dateTime{};
const bool readOk = M5.Rtc.getDateTime(&dateTime);
M5.Display.fillScreen(BLACK);
if (readOk) {
Serial.printf("RTC: %04d-%02d-%02d %02d:%02d:%02d, IRQ=%s\n",
dateTime.date.year, dateTime.date.month,
dateTime.date.date, dateTime.time.hours,
dateTime.time.minutes, dateTime.time.seconds,
displayIrq ? "FIRED" : "WAITING");
M5.Display.printf("%04d-%02d-%02d\n%02d:%02d:%02d\n",
dateTime.time.minutes, dateTime.time.seconds);
Serial.println("RTC read failed");
M5.Display.println("RTC read failed");
M5.Display.printf("IRQ: %s", displayIrq ? "FIRED" : "WAITING");
delay(100);
After uploading and running the program, the CoreS3 display shows the current RTC date and time from Stamp Timer Power. The timer triggers an IRQ approximately every 5 seconds. Set the Serial Monitor baud rate to 115200 to see output similar to the following:
Example serial output:
RTC timer: 5 seconds
RTC: 2026-09-02 12:00:00, IRQ=WAITING
RTC: 2026-09-02 12:00:01, IRQ=WAITING
RTC: 2026-09-02 12:00:04, IRQ=WAITING
RTC timer fired
RTC: 2026-09-02 12:00:05, IRQ=FIRED
RTC: 2026-09-02 12:00:09, IRQ=WAITING
RTC timer fired
RTC: 2026-09-02 12:00:10, IRQ=WAITING
