Environment Setup: Refer to the Arduino IDE Getting Started Guide to install the IDE, then install the board package for the development board you are using and the required driver libraries.
Required Driver Libraries:
Hardware Products Used:
G12 (SDA) and G11 (SCL).#include <M5Unified.h>
#include <Wire.h>
#include "Adafruit_PWMServoDriver.h"
#define SERVO_FREQ 50 // Servo PWM frequency.
#define SERVO2_I2C_ADDRESS 0x41
Adafruit_PWMServoDriver* pwm = nullptr;
auto cfg = M5.config();
M5.begin(cfg);
M5.Lcd.setFont(&fonts::FreeMonoBold12pt7b);
// Get M5Bus I2C pins.
const int8_t wireSda = M5.getPin(m5::pin_name_t::in_i2c_sda);
const int8_t wireScl = M5.getPin(m5::pin_name_t::in_i2c_scl);
// Find the configured SERVO2 address.
Serial.printf("Scanning SERVO2 address 0x%02X...\n", SERVO2_I2C_ADDRESS);
if (M5.In_I2C.scanID(SERVO2_I2C_ADDRESS)) {
Serial.printf("Found PCA9685 at 0x%02X\n", SERVO2_I2C_ADDRESS);
Serial.println("PCA9685 not found on M5Bus");
M5.Display.drawString("PCA9685 not found", 10, 80);
while (true) {
Wire.setPins(wireSda, wireScl);
pwm = new Adafruit_PWMServoDriver(SERVO2_I2C_ADDRESS, Wire);
if (!pwm->begin()) {
Serial.printf("Wire could not initialize PCA9685 at 0x%02X\n", SERVO2_I2C_ADDRESS);
M5.Display.drawString("Wire init failed", 10, 80);
while (true) {
// Set the PWM frequency for analog servos.
pwm->setPWMFreq(SERVO_FREQ);
M5.Lcd.setTextColor(TFT_GREEN, TFT_BLACK);
M5.Lcd.drawCenterString("Module13.2 Servo2 Test", 160, 10);
// Set one PCA9685 channel using a pulse width in milliseconds.
void setServoPulse(uint8_t n, double pulse)
double pulselength;
// Calculate the PWM period in microseconds.
pulselength = 1000000;
pulselength /= SERVO_FREQ;
// Print the period for debugging.
Serial.print(pulselength);
Serial.println(" us per period");
// Convert the period to one 12-bit PWM step.
pulselength /= 4096;
Serial.println(" us per bit");
// Convert the pulse width from milliseconds to PWM steps.
pulse *= 1000;
pulse /= pulselength;
Serial.println(pulse);
// Output the requested high pulse.
pwm->setPWM(n, 0, pulse);
// Drive all channels with a 0.5 ms pulse.
for (int i = 0; i < 16; i++) {
setServoPulse(i, 0.5);
M5.Lcd.fillRect(0, 70, 320, 20, TFT_BLACK);
M5.Lcd.drawCenterString("Pulse width: 0.5 ms", 160, 80);
// Drive all channels with a 2.5 ms pulse.
setServoPulse(i, 2.5);
M5.Lcd.drawCenterString("Pulse width: 2.5 ms", 160, 80);
}0x70 enabled by default for synchronizing multiple chips. After power-on, the module responds not only to requests sent to its own I2C communication address (0x40 ~ 0x47), but also to the ALL_CALL I2C address 0x70. If a device with the same address is connected to the current I2C bus, an address conflict will occur and communication may fail. This can be resolved by configuring the ALLCALL bit (bit:0) in the PCA9685 MODE1 register (0x00H) to 0 to disable the ALL_CALL function.#include <M5Unified.h>
#include <Wire.h>
constexpr uint8_t PCA9685_MODE1_REG = 0x00;
constexpr uint8_t PCA9685_ALLCALL_BIT = 0x01;
bool readRegister8(uint8_t address, uint8_t reg, uint8_t &value)
Wire.beginTransmission(address);
Wire.write(reg);
if (Wire.endTransmission(false) != 0) {
return false;
if (Wire.requestFrom(address, static_cast<uint8_t>(1)) != 1) {
return false;
value = Wire.read();
return true;
bool writeRegister8(uint8_t address, uint8_t reg, uint8_t value)
Wire.write(reg);
Wire.write(value);
return Wire.endTransmission(true) == 0;
bool setAllCall(uint8_t address, bool enable)
uint8_t mode1 = 0;
if (!readRegister8(address, PCA9685_MODE1_REG, mode1)) {
return false;
// Set or clear MODE1 bit 0 and preserve the other MODE1 bits.
if (enable) {
mode1 |= PCA9685_ALLCALL_BIT;
mode1 &= static_cast<uint8_t>(~PCA9685_ALLCALL_BIT);
return writeRegister8(address, PCA9685_MODE1_REG, mode1);
bool probeI2C(uint8_t address)
M5.begin(cfg);
delay(500);
Wire.begin();
if (!probeI2C(SERVO2_I2C_ADDRESS)) {
Serial.printf("PCA9685 not found at 0x%02X\n", SERVO2_I2C_ADDRESS);
while (true) {
// Enable ALL_CALL and test the 0x70 address.
if (setAllCall(SERVO2_I2C_ADDRESS, true)) {
uint8_t mode1 = 0;
if (readRegister8(SERVO2_I2C_ADDRESS, PCA9685_MODE1_REG, mode1)) {
Serial.printf("ALL_CALL enabled, MODE1: 0x%02X\n", mode1);
Serial.println("ALL_CALL enabled, but MODE1 readback failed");
Serial.println("Failed to enable ALL_CALL");
Serial.println("Test 0x70 with ALL_CALL enabled:");
if (probeI2C(0x70)) {
Serial.println("0x70: ACK");
Serial.println("0x70: NACK");
// Disable ALL_CALL and test the 0x70 address again.
if (setAllCall(SERVO2_I2C_ADDRESS, false)) {
uint8_t mode1 = 0;
Serial.printf("ALL_CALL disabled, MODE1: 0x%02X\n", mode1);
Serial.println("ALL_CALL disabled, but MODE1 readback failed");
Serial.println("Failed to disable ALL_CALL");
Serial.println("Test 0x70 with ALL_CALL disabled:");
}Serial output example:
ALL_CALL disabled
MODE1: 0x20
0x70: NACK
ALL_CALL enabled, MODE1: 0x21
0x70: ACK
ALL_CALL disabled, MODE1: 0x20
0x70: NACK
