环境配置:参考 Arduino IDE 上手教程 完成 IDE 安装,并根据实际使用的开发板安装对应的板管理与需要的驱动库。
使用到的驱动库:
使用到的硬件产品:
使用 Chain Bridge 连接器连接 Chain Captain 和 Chain DLight。连接时需要注意方向,三角箭头从主控指向外侧,主控侧接法如下:
#include "M5Chain.h"
#include "M5Unified.h"
#define TXD_PIN GPIO_NUM_18
#define RXD_PIN GPIO_NUM_17
Chain M5Chain;
M5Canvas canvas(&M5.Display);
uint8_t dlight_id = 0;
uint8_t op_status = 0;
// Find the first DLight node on the Chain bus.
bool findDLight()
uint16_t count = 0;
if (M5Chain.getDeviceNum(&count) != CHAIN_OK) {
Serial.println("Failed to get Chain device count");
return false;
Serial.printf("Chain device count: %u\r\n", count);
if (count == 0) {
return false;
device_info_t infos[8];
device_list_t list = {count < 8 ? count : 8, infos};
if (!M5Chain.getDeviceList(&list)) {
Serial.println("Failed to get Chain device list");
return false;
for (uint16_t i = 0; i < list.count; i++) {
if (list.devices[i].device_type == CHAIN_DLIGHT_TYPE_CODE) {
dlight_id = list.devices[i].id;
Serial.printf("DLight found, id=%u\r\n", dlight_id);
return true;
Serial.println("DLight not found");
return false;
void showMessage(const char *text)
canvas.fillSprite(TFT_BLACK);
canvas.setTextDatum(middle_center);
canvas.setTextColor(TFT_WHITE, TFT_BLACK);
canvas.setFont(&fonts::FreeSansBold12pt7b);
canvas.drawString(text, 120, 120);
canvas.pushSprite(0, 0);
delay(520);
// Initialize Chain Captain; Chain 5V is enabled by default.
M5.Display.setBrightness(255);
Serial.println("Chain DLight data demo start");
Serial.printf("Chain UART: RX=GPIO%d, TX=GPIO%d\r\n", RXD_PIN, TXD_PIN);
// Start the Chain bus on UART1.
M5Chain.begin(&Serial1, 115200, RXD_PIN, TXD_PIN);
if (!findDLight()) {
Serial.println("DLight init failed: device not found");
showMessage("DLight not found");
while (1) {
delay(100);
// Set gain, resolution, and measurement period.
bool config_ok =
M5Chain.setDLightSensorGain(dlight_id, CHAIN_DLIGHT_GAIN_6X, &op_status) == CHAIN_OK &&
op_status == 1 &&
M5Chain.setDLightSensorResolution(dlight_id, CHAIN_DLIGHT_RESOLUTION_17BIT_50MS,
op_status == 1 &&
M5Chain.setDLightSensorRate(dlight_id, CHAIN_DLIGHT_RATE_100MS, &op_status) == CHAIN_OK &&
op_status == 1;
if (!config_ok) {
Serial.printf("DLight config failed, operation status=%u\r\n", op_status);
showMessage("Config failed");
while (1) {
delay(100);
Serial.println("DLight config: gain=6x, resolution=17bit/50ms, period=100ms");
Serial.println("DLight ready");
showMessage("DLight ready");
uint32_t lux = 0;
if (M5Chain.getDLightLux(dlight_id, &lux) == CHAIN_OK) {
Serial.printf("DLight lux: %lu lx\r\n", (unsigned long)lux);
// Draw a compact dashboard with a large lux value.
canvas.setTextColor(TFT_CYAN, TFT_BLACK);
canvas.drawString("Chain DLight", 120, 24);
canvas.setFont(&fonts::FreeSans9pt7b);
canvas.setTextColor(TFT_LIGHTGREY, TFT_BLACK);
canvas.drawString("ILLUMINANCE", 120, 62);
canvas.setFont(&fonts::FreeSansBold24pt7b);
canvas.setTextColor(TFT_GREEN, TFT_BLACK);
canvas.drawString(String((unsigned long)lux) + " lx", 120, 112);
canvas.drawString("GAIN 6x RES 17-bit", 120, 168);
canvas.drawString("PERIOD 100 ms", 120, 198);
Serial.println("DLight read failed");
showMessage("Read failed");
delay(50);
}屏幕显示当前照度、增益、分辨率和测量周期;串口同步输出设备信息、配置结果和照度值。示例使用 17-bit 分辨率(转换时间 50 ms)和 100 ms 测量周期。
Chain M5Chain;
bool findDLight()
uint16_t count = 0;
return false;
if (count == 0) {
return false;
return false;
return true;
return false;
delay(520);
Serial.println("Chain DLight event demo start");
Serial.println("DLight event init failed: device not found");
while (1) {
delay(100);
// Set high/low lux thresholds and enable event reporting.
bool config_ok =
op_status == 1 &&
op_status == 1 &&
M5Chain.setDLightLuxInterruptThreshold(dlight_id, 2047, 120, &op_status) == CHAIN_OK &&
op_status == 1 &&
M5Chain.setDLightLuxInterruptEnable(dlight_id, CHAIN_DLIGHT_ENABLE, &op_status) == CHAIN_OK &&
op_status == 1 &&
M5Chain.setDLightLuxInterruptEventTriggerMode(dlight_id, CHAIN_DLIGHT_ENABLE,
op_status == 1;
if (!config_ok) {
Serial.printf("DLight event config failed, operation status=%u\r\n", op_status);
while (1) {
delay(100);
Serial.println("DLight event config: resolution=17bit/50ms, period=100ms, low=120 lx, high=2047 lx");
Serial.println("DLight event ready");
showMessage("Event ready");
chain_dlight_event_trigger_t event;
// Process all pending DLight event records.
while (M5Chain.getDLightLuxTrigger(dlight_id, &event)) {
// Decode the event type and status byte.
uint16_t record = (uint16_t)event;
if ((record >> 8) != CHAIN_DLIGHT_TYPE_CODE) {
Serial.printf("Unknown DLight event record: 0x%04X\r\n", record);
continue;
const char *text = "Unknown";
uint16_t event_color = TFT_WHITE;
switch ((uint8_t)record) {
case CHAIN_DLIGHT_REPORT_LUX_LOW:
text = "Low threshold";
event_color = TFT_BLUE;
break;
case CHAIN_DLIGHT_REPORT_LUX_HIGH:
text = "High threshold";
event_color = TFT_RED;
break;
Serial.printf("DLight event: %s, record=0x%04X\r\n", text, record);
// Highlight the latest threshold event.
canvas.drawString("Chain DLight Event", 120, 24);
canvas.drawString("EVENT", 120, 62);
canvas.setFont(&fonts::FreeSansBold18pt7b);
canvas.setTextColor(event_color, TFT_BLACK);
canvas.drawString(text, 120, 112);
canvas.drawString("HIGH 2047 lx", 120, 168);
canvas.drawString("LOW 120 lx", 120, 198);
delay(20);
}屏幕显示最近一次照度阈值触发结果:High threshold 表示照度向上越过高阈值,Low threshold 表示向下越过低阈值,高低阈值分别设置为的 2047 lx 和 120 lx;串口同步输出事件名称和原始记录。事件示例使用 17-bit 分辨率(转换时间 50 ms)和 100 ms 测量周期。
