Arduino 上手教程
2. 设备开发 & 案例程序
5. 扩展模块
6. 应用案例
Chain IMU 使用教程
1.准备工作
2.示例程序
使用 Chain Bridge 连接器连接 Chain Captain 和 Chain IMU。连接时需要注意方向,三角箭头从主控指向外侧,主控侧接法如下:
数据读取
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143
#include "M5Chain.h"
#include "M5Unified.h"
#define TXD_PIN GPIO_NUM_18
#define RXD_PIN GPIO_NUM_17
Chain M5Chain;
M5Canvas canvas(&M5.Display);
uint8_t imu_id = 0;
uint8_t op_status = 0;
// Find the first IMU node on the Chain bus.
bool findIMU()
    uint16_t count = 0;
    if (M5Chain.getDeviceNum(&count) != CHAIN_OK) {
        Serial.println("Failed to get Chain device count");
        return false;
    Serial.printf("Chain device count: %u\r\n", count);
    if (count == 0) {
        return false;
    device_info_t infos[8];
    device_list_t list = {count < 8 ? count : 8, infos};
    if (!M5Chain.getDeviceList(&list)) {
        Serial.println("Failed to get Chain device list");
        return false;
    for (uint16_t i = 0; i < list.count; i++) {
        if (list.devices[i].device_type == CHAIN_IMU_TYPE_CODE) {
            imu_id = list.devices[i].id;
            Serial.printf("IMU found, id=%u\r\n", imu_id);
            return true;
    Serial.println("IMU not found");
    return false;
void showMessage(const char *text)
    canvas.fillSprite(TFT_BLACK);
    canvas.setTextDatum(middle_center);
    canvas.setTextColor(TFT_WHITE, TFT_BLACK);
    canvas.setFont(&fonts::FreeSansBold12pt7b);
    canvas.drawString(text, 120, 120);
    canvas.pushSprite(0, 0);
    delay(520);
    // Initialize Chain Captain; Chain 5V is enabled by default.
    M5.Display.setBrightness(255);
    Serial.println("Chain IMU data demo start");
    Serial.printf("Chain UART: RX=GPIO%d, TX=GPIO%d\r\n", RXD_PIN, TXD_PIN);
    // Start the Chain bus on UART1.
    M5Chain.begin(&Serial1, 115200, RXD_PIN, TXD_PIN);
    if (!findIMU()) {
        Serial.println("IMU init failed: device not found");
        showMessage("IMU not found");
        while (1) {
            delay(100);
    // Configure accelerometer and gyroscope ranges and output rates.
    bool config_ok =
        M5Chain.setIMUAccelRange(imu_id, CHAIN_IMU_ACCEL_RANGE_4G, &op_status) == CHAIN_OK &&
        op_status == 1 &&
        M5Chain.setIMUGyroRange(imu_id, CHAIN_IMU_GYRO_RANGE_500DPS, &op_status) == CHAIN_OK &&
        op_status == 1 &&
        M5Chain.setIMUAccelODR(imu_id, CHAIN_IMU_ACCEL_ODR_104HZ, &op_status) == CHAIN_OK &&
        op_status == 1 &&
        M5Chain.setIMUGyroODR(imu_id, CHAIN_IMU_GYRO_ODR_104HZ, &op_status) == CHAIN_OK &&
        op_status == 1;
    if (!config_ok) {
        Serial.printf("IMU config failed, operation status=%u\r\n", op_status);
        showMessage("Config failed");
        while (1) {
            delay(100);
    Serial.println("IMU config: range=4g/500dps, ODR=104Hz");
    Serial.println("IMU ready");
    showMessage("IMU ready");
    int16_t ax = 0, ay = 0, az = 0;
    int16_t gx = 0, gy = 0, gz = 0;
    uint16_t temp = 0;
    if (M5Chain.getIMUAccelData(imu_id, &ax, &ay, &az) == CHAIN_OK &&
        M5Chain.getIMUGyroData(imu_id, &gx, &gy, &gz) == CHAIN_OK &&
        M5Chain.getIMUTemperature(imu_id, &temp) == CHAIN_OK) {
        Serial.printf("IMU data: A=(%d,%d,%d) mg, G=(%d,%d,%d) dps, T=%.2f C\r\n",
                      ax, ay, az, gx, gy, gz, temp / 100.0f);
        // Draw a compact dashboard with a clear hierarchy.
        canvas.setTextColor(TFT_CYAN, TFT_BLACK);
        canvas.drawString("Chain IMU", 120, 24);
        canvas.setFont(&fonts::FreeSans9pt7b);
        canvas.setTextColor(TFT_LIGHTGREY, TFT_BLACK);
        canvas.drawString("ACCEL (mg)", 120, 54);
        canvas.drawString(String(ax) + " / " + String(ay) + " / " + String(az), 120, 82);
        canvas.drawString("GYRO (dps)", 120, 112);
        canvas.drawString(String(gx) + " / " + String(gy) + " / " + String(gz), 120, 140);
        canvas.drawString("TEMP", 120, 174);
        canvas.setTextColor(TFT_GREEN, TFT_BLACK);
        canvas.drawString(String(temp / 100.0f, 2) + " C", 120, 202);
        Serial.println("IMU data read failed");
        showMessage("Read failed");
    delay(50);
屏幕显示三轴加速度(mg)、三轴角速度(dps)和传感器温度;串口同步输出设备信息、配置结果和实时数据。
阈值事件
下述示例同时开启加速度、角速度和温度事件,分别设置 40 mg、40 dps 和 0~30°C 阈值。
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151
Chain M5Chain;
uint8_t imu_id = 0;
uint8_t last_status = 0;
bool event_pending = false;
uint32_t last_draw_ms = 0;
const uint32_t event_hold_ms = 250;  // Minimum time between event screen updates.
const char *const temp_text[] = {"TEMP HIGH RELEASE", "TEMP HIGH ACTIVE",
                                 "TEMP LOW ACTIVE", "TEMP LOW RELEASE"};
bool findIMU()
    uint16_t count = 0;
        return false;
    if (count == 0) {
        return false;
        return false;
            return true;
    return false;
void drawEvent(uint8_t status)
    bool accel = status & CHAIN_IMU_EVENT_STATUS_ACCEL_MASK;
    bool gyro  = status & CHAIN_IMU_EVENT_STATUS_GYRO_MASK;
    uint8_t temp = (status & CHAIN_IMU_EVENT_STATUS_TEMPERATURE_MASK) >>
                   CHAIN_IMU_EVENT_STATUS_TEMPERATURE_SHIFT;
    canvas.drawString("Chain IMU Event", 120, 32);
    canvas.setTextColor(accel ? TFT_BLUE : TFT_GREEN, TFT_BLACK);
    canvas.drawString(accel ? "ACC ACTIVE" : "ACC RELEASE", 120, 88);
    canvas.setTextColor(gyro ? TFT_BLUE : TFT_GREEN, TFT_BLACK);
    canvas.drawString(gyro ? "GYRO ACTIVE" : "GYRO RELEASE", 120, 132);
    canvas.setFont(&fonts::FreeSansBold9pt7b);
    canvas.setTextColor((temp == 1 || temp == 2) ? TFT_RED : TFT_GREEN, TFT_BLACK);
    canvas.drawString(temp_text[temp], 120, 176);
    delay(520);
    Serial.println("Chain IMU event demo start");
    if (!findIMU()) {
        Serial.println("IMU event init failed: device not found");
        while (1) {
            delay(100);
    // Enable acceleration, gyro, and temperature event reporting.
    uint8_t mode = CHAIN_IMU_EVENT_MODE_ACCEL | CHAIN_IMU_EVENT_MODE_GYRO |
                   CHAIN_IMU_EVENT_MODE_TEMPERATURE;
    bool config_ok =
        M5Chain.setIMUEventTriggerMode(imu_id, mode, &op_status) == CHAIN_OK && op_status == 1 &&
        M5Chain.setIMU6AxisWarningThreshold(imu_id, 40, 40, &op_status) == CHAIN_OK &&
        op_status == 1 &&
        M5Chain.setIMUTemperatureWarningThreshold(imu_id, 0, 30, &op_status) == CHAIN_OK &&
        op_status == 1;
    if (!config_ok) {
        Serial.printf("IMU event config failed, operation status=%u\r\n", op_status);
        while (1) {
            delay(100);
    Serial.println("IMU event config: accel=40 mg, gyro=40 dps, temp=0-30 C");
    Serial.println("IMU event ready");
    showMessage("Event ready");
    uint8_t status = 0;
    // Keep the serial log complete while limiting screen redraws.
    while (M5Chain.getIMUEventTrigger(imu_id, &status)) {
        last_status = status;
        event_pending = true;
        Serial.printf("IMU event: %s, %s, %s\r\n",
                      gyro ? "GYRO ACTIVE" : "GYRO RELEASE", temp_text[temp]);
    uint32_t now = millis();
    if (event_pending && (last_draw_ms == 0 || now - last_draw_ms >= event_hold_ms)) {
        drawEvent(last_status);
        last_draw_ms = now;
    delay(20);
晃动设备,屏幕会显示最近一次事件的可读状态文本:
  • ACC ACTIVE / ACC RELEASE
  • GYRO ACTIVE / GYRO RELEASE
  • TEMP HIGH ACTIVE / TEMP HIGH RELEASE
  • TEMP LOW ACTIVE / TEMP LOW RELEASE
