Arduino 上手教程
#include "M5Chain.h"
#define RXD_PIN GPIO_NUM_5 // 47 for the other side of Chain DualKey
#define TXD_PIN GPIO_NUM_6 // 48 for the other side of Chain DualKey
Chain M5Chain;
device_info_t devices[8];
device_list_t device_list = {0, devices};
uint16_t device_count = 0;
#define START_KEY_PIN GPIO_NUM_0
#define STOP_KEY_PIN GPIO_NUM_17
uint8_t mic_id = 0;
bool mic_found = false;
bool print_adc = false;
bool start_key_last = HIGH;
bool stop_key_last = HIGH;
Serial.println("M5Stack Chain MIC Test");
pinMode(START_KEY_PIN, INPUT_PULLUP);
pinMode(STOP_KEY_PIN, INPUT_PULLUP);
if (M5Chain.getDeviceNum(&device_count) != CHAIN_OK || device_count == 0) {
Serial.println("Failed to get device count");
return;
device_list.count = device_count < 8 ? device_count : 8;
if (!M5Chain.getDeviceList(&device_list)) {
Serial.println("Failed to get device list");
return;
for (uint16_t i = 0; i < device_list.count; i++) {
if (device_list.devices[i].device_type == CHAIN_MIC_TYPE_CODE) {
mic_id = device_list.devices[i].id;
mic_found = true;
Serial.printf("ID[%d] is Chain MIC\n", mic_id);
break;
if (!mic_found) {
Serial.println("Chain MIC not found");
return;
Serial.println("Press KEY1 to start ADC output");
Serial.println("Press KEY2 to stop ADC output");
const bool start_key = digitalRead(START_KEY_PIN);
const bool stop_key = digitalRead(STOP_KEY_PIN);
if (start_key == LOW && start_key_last == HIGH) {
print_adc = true;
Serial.println("ADC_PRINT_START");
if (stop_key == LOW && stop_key_last == HIGH) {
print_adc = false;
Serial.println("ADC_PRINT_STOP");
start_key_last = start_key;
stop_key_last = stop_key;
if (!mic_found || !print_adc) {
delay(10);
return;
uint16_t adc = 0;
if (M5Chain.getMIC12BitAdc(mic_id, &adc) == CHAIN_OK) {
Serial.print("MIC ADC=");
Serial.println(adc);
Serial.println("MIC ADC read failed");
delay(100);
}用 Chain Bridge 连接器连接主控 Chain DualKey 和 Chain MIC。连接时需要注意方向,三角箭头从主控 Chain DualKey 指向外侧,如图:
本案例使用 Chain DualKey 的 GPIO5 作为 RX、GPIO6 作为 TX,KEY1(GPIO0)作为开始按键,KEY2(GPIO17)作为停止按键。若将 Chain MIC 连接到 Chain DualKey 的另一侧接口,请根据实际接线修改程序中的 RXD_PIN 和 TXD_PIN。
将以上程序编译并上传至 Chain DualKey,点击 Arduino IDE 右上角的按钮打开串口监视器(Serial Monitor)。按下 KEY1 后开始打印 Chain MIC 的 12 位 ADC 值(范围 0 ~ 4095),每 100 ms 输出一次;按下 KEY2 后停止打印。串口输出 ADC_PRINT_START 或 ADC_PRINT_STOP 可用于确认按键状态。
例程效果如下:
