Arduino 上手教程
2. 设备开发 & 案例程序
5. 扩展模块
6. 应用案例
Chain Mono 使用教程
1.准备工作
2.示例程序
像素模式
单像素控制及批量写入
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143
#include "M5Chain.h"
#include "M5Unified.h"
#define TXD_PIN GPIO_NUM_2
#define RXD_PIN GPIO_NUM_1
Chain M5Chain;
chain_status_t chain_status = CHAIN_OK;
uint8_t mono_id          = 0;
uint8_t operation_status = 0;
bool findFirstMonoDevice()
    // Enumerate devices and use the first Mono node
    uint16_t device_nums = 0;
    if (M5Chain.getDeviceNum(&device_nums) != CHAIN_OK || device_nums == 0) {
        return false;
    device_info_t *infos = (device_info_t *)malloc(sizeof(device_info_t) * device_nums);
    if (infos == nullptr) {
        return false;
    device_list_t devices;
    devices.count   = device_nums;
    devices.devices = infos;
    bool found = false;
    if (M5Chain.getDeviceList(&devices)) {
        for (uint8_t i = 0; i < devices.count; i++) {
            if (devices.devices[i].device_type == CHAIN_MONO_TYPE_CODE) {
                mono_id = devices.devices[i].id;
                found   = true;
                break;
    free(infos);
    if (found) {
        Serial.printf("Mono device found, id=%d\r\n", mono_id);
        Serial.println("No Mono device found");
    return found;
bool prepareMono()
    // Initialize display mode, rotation, and brightness
    if (!findFirstMonoDevice()) {
        return false;
    if (M5Chain.setMonoMode(mono_id, MONO_PIXEL_MODE, &operation_status) != CHAIN_OK || operation_status != 1) {
        return false;
    M5Chain.setMonoRotation(mono_id, MONO_ROTATION_0, &operation_status);
    M5Chain.setMonoBrightness(mono_id, MONO_BRIGHTNESS_LEVEL_7, &operation_status);
    M5Chain.setMonoClear(mono_id, &operation_status);
    return true;
    Serial.println("Pixel demo");
    if (!prepareMono()) {
        Serial.println("Chain Mono init failed");
        while (1) {
            delay(100);
        Serial.println("Chain Mono init success");
    static bool single_phase = true;
    static uint8_t single_x  = 0;
    static uint8_t single_y  = 0;
    static uint8_t block_x   = 0;
    static uint8_t block_y   = 4;
    if (single_phase) {
        // Walk through the first 4 rows with a single pixel
        chain_status = M5Chain.setMonoPixel(mono_id, single_x, single_y, true, &operation_status);
        if (chain_status == CHAIN_OK && operation_status == 1) {
            Serial.printf("Single pixel on: x=%d, y=%d\r\n", single_x, single_y);
        delay(200);
        single_x++;
        if (single_x >= 8) {
            single_x = 0;
            single_y++;
        if (single_y >= 4) {
            single_phase = false;
            block_x      = 0;
            block_y      = 4;
        // Walk through the last 4 rows with a 2x2 block
        MonoPixelInfo pixels[] = {
            {block_x, block_y, true},
            {(uint8_t)(block_x + 1), block_y, true},
            {block_x, (uint8_t)(block_y + 1), true},
            {(uint8_t)(block_x + 1), (uint8_t)(block_y + 1), true}};
        chain_status = M5Chain.setMonoPixel(mono_id, pixels, sizeof(pixels) / sizeof(pixels[0]), &operation_status);
            Serial.printf("Block on: (%d,%d) (%d,%d) (%d,%d) (%d,%d)\r\n", pixels[0].x, pixels[0].y, pixels[1].x,
                          pixels[1].y, pixels[2].x, pixels[2].y, pixels[3].x, pixels[3].y);
        delay(200);
        block_x++;
        if (block_x >= 7) {
            block_x = 0;
            block_y += 2;
        if (block_y >= 8) {
            single_x     = 0;
            single_y     = 0;
例程效果如下:
字符显示
Chain M5Chain;
const char text[]        = "I'mChainMono";
        return false;
        return false;
    bool found = false;
                found   = true;
                break;
    free(infos);
    if (found) {
    return found;
bool prepareMono()
        return false;
        return false;
    return true;
    Serial.println("Character display demo");
        while (1) {
            delay(100);
    static uint8_t index = 0;
    // Show characters one by one from the array
    M5Chain.setMonoPrintChar(mono_id, text[index], 1, 1, &operation_status);
    Serial.printf("Character shown: %c\r\n", text[index]);
    delay(400);
    index++;
    if (index >= sizeof(text) - 1) {
        index = 0;
例程效果如下:
自定义图案显示与旋转
说明
此处旋转指的是在绘制前对显示方向进行设置,设置后再进行的绘制操作都会以该方向为基准进行显示,并非直接对已绘制显示内容进行旋转变换。
Chain M5Chain;
// 8x8 arrow pattern
uint8_t arrow[8] = {
    0b00011000,  //    ■■
    0b00111100,  //   ■■■■
    0b01111110,  //  ■■■■■■
    0b11111111,  // ■■■■■■■■
    0b00111100,  //   ■■■■
    0b00111100,  //   ■■■■
    0b00111100,  //   ■■■■
    0b00111100   //   ■■■■
        return false;
        return false;
    bool found = false;
                found   = true;
                break;
    free(infos);
    if (found) {
    return found;
bool prepareMono()
    // Initialize pixel mode and brightness
        return false;
        return false;
    return true;
    Serial.println("Custom pattern rotation demo");
        while (1) {
            delay(100);
    // Rotate through 0/90/180/270 degree display states
    for (uint8_t rotation = MONO_ROTATION_0; rotation <= MONO_ROTATION_270; rotation++) {
        M5Chain.setMonoRotation(mono_id, (mono_rotation_t)rotation, &operation_status);
        M5Chain.setMonoBufferRefresh(mono_id, arrow, &operation_status);
        Serial.printf("Rotation set to: %d°\r\n", rotation*90);
        delay(800);
例程效果如下:
字符串滚动模式
Chain M5Chain;
const char text[]        = "Hi I'm Chain Mono! ";
        return false;
        return false;
    bool found = false;
                found   = true;
                break;
    free(infos);
    if (found) {
    return found;
bool prepareMono()
    // Switch to string scroll mode and set basic parameters
        return false;
    if (M5Chain.setMonoMode(mono_id, MONO_STRING_SCROLL_MODE, &operation_status) != CHAIN_OK ||
        return false;
    return true;
    Serial.println("Mono string scroll demo");
        while (1) {
            delay(100);
    chain_status = M5Chain.setMonoStringScroll(mono_id, text, MONO_SCROLL_LEFT, MONO_SCROLL_MODE_LOOP, 100,
                                               &operation_status);
        Serial.printf("String scroll started: %s\r\n", text);
例程效果如下:
