Arduino 上手教程
2. 设备开发 & 案例程序
5. 扩展模块
6. 应用案例
Chain RGB 使用教程
1.准备工作
2.示例程序
实际连接如下:
像素模式
单像素控制及批量写入
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154
#include "M5Chain.h"
#include "M5Unified.h"
#define TXD_PIN GPIO_NUM_2
#define RXD_PIN GPIO_NUM_1
Chain M5Chain;
chain_status_t chain_status = CHAIN_OK;
uint8_t rgb_id           = 0;
uint8_t operation_status = 0;
const uint16_t colors[] = {
    0xF800,  // Red
    0x07E0,  // Green
    0x001F,  // Blue
    0xFFE0,  // Yellow
    0xF81F,  // Magenta
    0x07FF   // Cyan
bool findFirstRGBDevice()
    // Enumerate devices and use the first RGB node
    uint16_t device_nums = 0;
    if (M5Chain.getDeviceNum(&device_nums) != CHAIN_OK || device_nums == 0) {
        return false;
    device_info_t *infos = (device_info_t *)malloc(sizeof(device_info_t) * device_nums);
    if (infos == nullptr) {
        return false;
    device_list_t devices;
    devices.count   = device_nums;
    devices.devices = infos;
    bool found = false;
    if (M5Chain.getDeviceList(&devices)) {
        for (uint8_t i = 0; i < devices.count; i++) {
            if (devices.devices[i].device_type == CHAIN_RGB_TYPE_CODE) {
                rgb_id = devices.devices[i].id;
                found  = true;
                break;
    free(infos);
    if (found) {
        Serial.printf("RGB device found, id=%d\r\n", rgb_id);
        Serial.println("No RGB device found");
    return found;
bool prepareRGB()
    // Initialize pixel mode, rotation, and brightness
    if (!findFirstRGBDevice()) {
        return false;
    if (M5Chain.setRGBMode(rgb_id, RGB_PIXEL_MODE, &operation_status) != CHAIN_OK || operation_status != 1) {
        return false;
    M5Chain.setRGBRotation(rgb_id, RGB_ROTATION_0, &operation_status);
    M5Chain.setRGBBrightness(rgb_id, 50, &operation_status);
    M5Chain.setRGBClear(rgb_id, &operation_status);
    return true;
    Serial.println("RGB pixel demo");
    if (!prepareRGB()) {
        Serial.println("Chain RGB init failed");
        while (1) {
            delay(100);
        Serial.println("Chain RGB init success");
    static bool single_phase = true;
    static uint8_t single_x  = 0;
    static uint8_t single_y  = 0;
    static uint8_t block_x   = 0;
    static uint8_t block_y   = 4;
    static uint8_t color_i   = 0;
    if (single_phase) {
        // Walk through the first 4 rows with one RGB pixel
        chain_status = M5Chain.setRGBPixel(rgb_id, single_x, single_y, colors[color_i], &operation_status);
        if (chain_status == CHAIN_OK && operation_status == 1) {
            Serial.printf("Single pixel: x=%d, y=%d, color=0x%04X\r\n", single_x, single_y, colors[color_i]);
        delay(160);
        single_x++;
        color_i = (color_i + 1) % (sizeof(colors) / sizeof(colors[0]));
        if (single_x >= 8) {
            single_x = 0;
            single_y++;
        if (single_y >= 4) {
            single_phase = false;
            block_x      = 0;
            block_y      = 4;
        // Walk through the last 4 rows with a 2x2 RGB block
        RGBPixelInfo pixels[] = {
            {block_x, block_y, colors[color_i]},
            {(uint8_t)(block_x + 1), block_y, colors[(color_i + 1) % 6]},
            {block_x, (uint8_t)(block_y + 1), colors[(color_i + 2) % 6]},
            {(uint8_t)(block_x + 1), (uint8_t)(block_y + 1), colors[(color_i + 3) % 6]}};
        chain_status = M5Chain.setRGBPixel(rgb_id, pixels, sizeof(pixels) / sizeof(pixels[0]), &operation_status);
            Serial.printf("RGB block: x=%d, y=%d\r\n", block_x, block_y);
        delay(160);
        block_x++;
        if (block_x >= 7) {
            block_x = 0;
            block_y += 2;
        if (block_y >= 8) {
            single_x     = 0;
            single_y     = 0;
例程效果如下:
字符显示
Chain M5Chain;
uint8_t rgb_id           = 0;
const char text[]        = "I'mChainRGB";
const uint16_t colors[]  = {0xFFE0, 0xF800, 0x07E0, 0x001F, 0xFD20, 0x07FF, 0xF81F};
        return false;
        return false;
    bool found = false;
                found  = true;
                break;
    free(infos);
    if (found) {
    return found;
bool prepareRGB()
        return false;
        return false;
    return true;
    Serial.println("RGB character demo");
        while (1) {
            delay(100);
    static uint8_t index = 0;
    char c               = text[index];
    uint16_t color       = colors[index % (sizeof(colors) / sizeof(colors[0]))];
    // Show characters one by one with changing colors
    M5Chain.setRGBPrintChar(rgb_id, c, 1, 1, color, &operation_status);
    Serial.printf("Character shown: %c, color=0x%04X\r\n", c, color);
    delay(400);
    index++;
    if (index >= sizeof(text) - 1) {
        index = 0;
例程效果如下:
自定义图案显示与旋转
说明
此处旋转指的是在绘制前对显示方向进行设置,设置后再进行的绘制操作都会以该方向为基准进行显示,并非直接对已绘制显示内容进行旋转变换。
Chain M5Chain;
uint8_t rgb_id           = 0;
// 8x8 green arrow pattern
uint16_t arrow[64] = {
    0x0000, 0x0000, 0x0000, 0x07E0, 0x07E0, 0x0000, 0x0000, 0x0000,  //    ■■
    0x0000, 0x0000, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x0000, 0x0000,  //   ■■■■
    0x0000, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x0000,  //  ■■■■■■
    0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x07E0,  // ■■■■■■■■
    0x0000, 0x0000, 0x07E0, 0x07E0, 0x07E0, 0x07E0, 0x0000, 0x0000   //   ■■■■
        return false;
        return false;
    bool found = false;
                found  = true;
                break;
    free(infos);
    if (found) {
    return found;
bool prepareRGB()
    // Initialize pixel mode and brightness
        return false;
        return false;
    return true;
    Serial.println("RGB custom pattern rotation demo");
        while (1) {
            delay(100);
    // Rotate through 0/90/180/270 degree display states
    for (uint8_t rotation = RGB_ROTATION_0; rotation <= RGB_ROTATION_270; rotation++) {
        M5Chain.setRGBRotation(rgb_id, (rgb_rotation_t)rotation, &operation_status);
        M5Chain.setRGBBufferRefresh(rgb_id, arrow, &operation_status);
        Serial.printf("Rotation set to: %d°\r\n", rotation * 90);
        delay(800);
例程效果如下:
动态色彩瀑布
Chain M5Chain;
uint8_t rgb_id           = 0;
uint16_t frame[64]       = {0};
uint8_t color_offset     = 0;
uint16_t color565(uint8_t r, uint8_t g, uint8_t b)
    return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
uint16_t wheel(uint8_t pos)
    if (pos < 85) {
        return color565(255 - pos * 3, pos * 3, 0);
    if (pos < 170) {
        pos -= 85;
        return color565(0, 255 - pos * 3, pos * 3);
    pos -= 170;
    return color565(pos * 3, 0, 255 - pos * 3);
        return false;
        return false;
    bool found = false;
                found  = true;
                break;
    free(infos);
    if (found) {
    return found;
bool prepareRGB()
        return false;
        return false;
    return true;
    Serial.println("RGB color waterfall demo");
        while (1) {
            delay(100);
    // Move old rows down by one row
    for (int y = 7; y > 0; y--) {
        for (int x = 0; x < 8; x++) {
            frame[y * 8 + x] = frame[(y - 1) * 8 + x];
    // Generate a new color row at the top
        frame[x] = wheel(color_offset + x * 16);
    M5Chain.setRGBBufferRefresh(rgb_id, frame, &operation_status);
    Serial.printf("Waterfall frame offset: %d\r\n", color_offset);
    color_offset += 4;
    delay(80);
例程效果如下:
字符串滚动模式
Chain M5Chain;
uint8_t rgb_id           = 0;
const char text[]        = "Hi I'm Chain RGB! ";
        return false;
        return false;
    bool found = false;
                found  = true;
                break;
    free(infos);
    if (found) {
    return found;
bool prepareRGB()
    // Switch to string scroll mode and set basic parameters
        return false;
    if (M5Chain.setRGBMode(rgb_id, RGB_STRING_SCROLL_MODE, &operation_status) != CHAIN_OK ||
        return false;
    M5Chain.setRGBBrightness(rgb_id, 30, &operation_status);
    return true;
    Serial.println("RGB string scroll demo");
        while (1) {
            delay(100);
    chain_status = M5Chain.setRGBStringScroll(rgb_id, text, RGB_SCROLL_LEFT, RGB_SCROLL_MODE_LOOP, 100,
                                              RGB_SCROLL_COLOR_GRADIENT, &operation_status);
    if(chain_status == CHAIN_OK && operation_status == 1) {
        Serial.printf("String scroll started: %s\r\n", text);
例程效果如下:
