環境設定: Arduino IDE 入門チュートリアル を参考に IDE のインストールを完了し、実際に使用する開発ボードに応じて対応するボードマネージャと必要なドライバライブラリをインストールします。
使用するドライバライブラリ:
使用するハードウェア製品:
#include "M5Chain.h"
#include "M5Unified.h"
#define TXD_PIN GPIO_NUM_2
#define RXD_PIN GPIO_NUM_1
Chain M5Chain;
chain_status_t chain_status = CHAIN_OK;
uint8_t mono_id = 0;
uint8_t operation_status = 0;
bool findFirstMonoDevice()
// Enumerate devices and use the first Mono node
uint16_t device_nums = 0;
if (M5Chain.getDeviceNum(&device_nums) != CHAIN_OK || device_nums == 0) {
return false;
device_info_t *infos = (device_info_t *)malloc(sizeof(device_info_t) * device_nums);
if (infos == nullptr) {
return false;
device_list_t devices;
devices.count = device_nums;
devices.devices = infos;
bool found = false;
if (M5Chain.getDeviceList(&devices)) {
for (uint8_t i = 0; i < devices.count; i++) {
if (devices.devices[i].device_type == CHAIN_MONO_TYPE_CODE) {
mono_id = devices.devices[i].id;
found = true;
break;
free(infos);
if (found) {
Serial.printf("Mono device found, id=%d\r\n", mono_id);
Serial.println("No Mono device found");
return found;
bool prepareMono()
// Initialize display mode, rotation, and brightness
if (!findFirstMonoDevice()) {
return false;
if (M5Chain.setMonoMode(mono_id, MONO_PIXEL_MODE, &operation_status) != CHAIN_OK || operation_status != 1) {
return false;
M5Chain.setMonoRotation(mono_id, MONO_ROTATION_0, &operation_status);
M5Chain.setMonoBrightness(mono_id, MONO_BRIGHTNESS_LEVEL_7, &operation_status);
M5Chain.setMonoClear(mono_id, &operation_status);
return true;
Serial.println("Pixel demo");
if (!prepareMono()) {
Serial.println("Chain Mono init failed");
while (1) {
delay(100);
Serial.println("Chain Mono init success");
static bool single_phase = true;
static uint8_t single_x = 0;
static uint8_t single_y = 0;
static uint8_t block_x = 0;
static uint8_t block_y = 4;
if (single_phase) {
// Walk through the first 4 rows with a single pixel
chain_status = M5Chain.setMonoPixel(mono_id, single_x, single_y, true, &operation_status);
if (chain_status == CHAIN_OK && operation_status == 1) {
Serial.printf("Single pixel on: x=%d, y=%d\r\n", single_x, single_y);
delay(200);
single_x++;
if (single_x >= 8) {
single_x = 0;
single_y++;
if (single_y >= 4) {
single_phase = false;
block_x = 0;
block_y = 4;
// Walk through the last 4 rows with a 2x2 block
MonoPixelInfo pixels[] = {
{block_x, block_y, true},
{(uint8_t)(block_x + 1), block_y, true},
{block_x, (uint8_t)(block_y + 1), true},
{(uint8_t)(block_x + 1), (uint8_t)(block_y + 1), true}};
chain_status = M5Chain.setMonoPixel(mono_id, pixels, sizeof(pixels) / sizeof(pixels[0]), &operation_status);
Serial.printf("Block on: (%d,%d) (%d,%d) (%d,%d) (%d,%d)\r\n", pixels[0].x, pixels[0].y, pixels[1].x,
pixels[1].y, pixels[2].x, pixels[2].y, pixels[3].x, pixels[3].y);
delay(200);
block_x++;
if (block_x >= 7) {
block_x = 0;
block_y += 2;
if (block_y >= 8) {
single_x = 0;
single_y = 0;
}サンプルの動作は以下のとおりです:
Chain M5Chain;
const char text[] = "I'mChainMono";
return false;
return false;
bool found = false;
found = true;
break;
free(infos);
if (found) {
return found;
bool prepareMono()
return false;
return false;
return true;
Serial.println("Character display demo");
while (1) {
delay(100);
static uint8_t index = 0;
// Show characters one by one from the array
M5Chain.setMonoPrintChar(mono_id, text[index], 1, 1, &operation_status);
Serial.printf("Character shown: %c\r\n", text[index]);
delay(400);
index++;
if (index >= sizeof(text) - 1) {
index = 0;
}サンプルの動作は以下のとおりです:
Chain M5Chain;
// 8x8 arrow pattern
uint8_t arrow[8] = {
0b00011000, // ■■
0b00111100, // ■■■■
0b01111110, // ■■■■■■
0b11111111, // ■■■■■■■■
0b00111100, // ■■■■
0b00111100, // ■■■■
0b00111100, // ■■■■
0b00111100 // ■■■■
return false;
return false;
bool found = false;
found = true;
break;
free(infos);
if (found) {
return found;
bool prepareMono()
// Initialize pixel mode and brightness
return false;
return false;
return true;
Serial.println("Custom pattern rotation demo");
while (1) {
delay(100);
// Rotate through 0/90/180/270 degree display states
for (uint8_t rotation = MONO_ROTATION_0; rotation <= MONO_ROTATION_270; rotation++) {
M5Chain.setMonoRotation(mono_id, (mono_rotation_t)rotation, &operation_status);
M5Chain.setMonoBufferRefresh(mono_id, arrow, &operation_status);
Serial.printf("Rotation set to: %d°\r\n", rotation*90);
delay(800);
}サンプルの動作は以下のとおりです:
Chain M5Chain;
const char text[] = "Hi I'm Chain Mono! ";
return false;
return false;
bool found = false;
found = true;
break;
free(infos);
if (found) {
return found;
bool prepareMono()
// Switch to string scroll mode and set basic parameters
return false;
if (M5Chain.setMonoMode(mono_id, MONO_STRING_SCROLL_MODE, &operation_status) != CHAIN_OK ||
return false;
return true;
Serial.println("Mono string scroll demo");
while (1) {
delay(100);
chain_status = M5Chain.setMonoStringScroll(mono_id, text, MONO_SCROLL_LEFT, MONO_SCROLL_MODE_LOOP, 100,
&operation_status);
Serial.printf("String scroll started: %s\r\n", text);
}サンプルの動作は以下のとおりです:
